02 S4 axle size?
Started by 118811, July 13, 2012, 10:37:05 AM
What size axle does the 02 s4 come with?  Found the answer 25mm :'(
Looking at wheels for my 98 M900...wont work
Thanks
I think you can just swap in appropriately sized bearings. Not 100%, but pretty sure.
I just measured my front axle...on the LH side, with digital calipers 17mm...while on the bike, can that be!!!?
Quote from: 118811 on July 13, 2012, 11:14:38 AM
Monster Axle sizes
1993-1999 20mm front | 17mm rear
2000-2001 25mm front | 17mm rear
2002-current 25mm front | 25mm rear (for dual sized swingarms)
Quote from: Slide Panda on July 13, 2012, 12:00:48 PM
Monster Axle sizes
The axle on my 96 is 17 mm.
The shoulder on the right side is 20 mm
Quote from: Slide Panda on July 13, 2012, 11:03:12 AM
The smaller ID bearings are also thinner. You'd need spacers to make up the difference.
118811
Quote from: ducpainter on July 13, 2012, 12:31:40 PM
So...new bearing's and spacer's & a 25mm front wheel would work?
Anyone here done this?
Quote from: 118811 on July 13, 2012, 01:02:30 PM
I'm pretty sure it's been done...not sure by who.
118811
Quote from: ducpainter on July 13, 2012, 01:04:52 PM
Thanks for everyone's advice/opinion's!!! [thumbsup]
I want new wheels for the M900....but not willing to get a whole new front end to achieve it.
After looking on ebay....at 749-999 wheels...they seem to be at good pricing...is the rear a direct bolt on?
Quote from: 118811 on July 13, 2012, 01:26:45 PM
Those wheels won't work with your rotors or calipers.
749/999 use 5 bolt rotors with a different offset.
118811
