February 23, 2025, 03:35:00 PM *
Pages: [1] 2   Go Down
Author Topic: Any Tips on mounting BoomTubes?  (Read 2705 times)
The ModFather
Duck Off
Monster Magnet
« on: July 13, 2012, 06:37:26 PM »
BoomTubes are finally on their way here for my 05 620. I'm very excited. I plan on mounting them myself. Any tips on the process would be very helpful.
Thanks!
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
hunduc
08 S2R1K
« Reply #1 on: July 14, 2012, 07:43:35 AM »
Nothing very specific, it is a very easy process. I'm pretty much all thumbs but managed to do it in an hour or so.
Do not forget to put back the gaskets, and make sure nothing leaks. It will be a piece of cake.
« Reply #2 on: July 14, 2012, 08:47:16 AM »
What he said.
I'd be surprised, and kind of impressed, if you managed to screw it up.
Post pictures if you do.
Hell, post pictures even if you get it right.  waytogo
DucatiBastard
"Apollonia" '06 S2R 800
« Reply #3 on: July 15, 2012, 06:01:35 PM »
You'll probably need a few pints of assembly fluid
 drink drink drink
Give a man a beer, and he wastes an hour.
Teach a man to brew, and he wastes a lifetime.
2006 Ducati S2R 800, 2004 Honda Dream 50R, 2001 Kawasaki W650, 1940 BSA M20
Novelo
« Reply #4 on: July 17, 2012, 07:24:35 PM »
Ear plugs
« Reply #5 on: July 17, 2012, 07:43:29 PM »
Ear plugs
 applause applause applause
...but yeah.
Necessary. Even around town.
The ModFather
Duck Off
Monster Magnet
« Reply #6 on: July 18, 2012, 05:55:28 AM »
I've been running with no exhaust since March as I sold my Remus to help fund the Boom Tubes. So I'm pretty used to loud. They are supposed to arrive today so I'll post a pic once they're mounted. Cant wait!
2008 848 Track Bike
Novelo
« Reply #7 on: July 18, 2012, 08:24:55 AM »
...but yeah.
I'd say so, hearing loss is progressive so you don't notice it that much when the damage is being done. I went with the utter for a while before I got my Booms and wasn't too terrible decibal wise but in hindsight I should have worn ear plugs. With the Booms running around town and what not I absolutely must. I like my hearing jamming to tunes and everything else associated with hearing. When I don't wear ear plugs my left ear drum hurts more than the right (diving incident/loss of hearing) and my ears get hot and thats enough for me to plug it up.
The ModFather
Duck Off
Monster Magnet
« Reply #8 on: July 18, 2012, 12:55:32 PM »
For me "all the gear all the time includes ear protection" I always wear ear plugs (cuz I'm married ) Grin
2008 848 Track Bike
The ModFather
Duck Off
Monster Magnet
« Reply #9 on: July 19, 2012, 08:50:03 AM »
Should I assemble the whole thing and then mount it or should I mount the two end points that attach to the engine and then attach the pipes in the middle?
2008 848 Track Bike
seanster
Wat???? Hero Member!?!?
« Reply #10 on: July 19, 2012, 10:09:36 AM »
Assemble by section would be better IMO.  avoid scratching stuff when you have very little room to work with.
hunduc
08 S2R1K
« Reply #11 on: July 19, 2012, 10:25:50 AM »
I do not think you can attach the vertical header in the assembled state. Do it disassembled.
The ModFather
Duck Off
Monster Magnet
« Reply #12 on: July 19, 2012, 10:45:26 AM »
Yeah I got a detailed response on this from Mark that I should probably post here for future searches on this topic. The real PITA is the rear header inside nut. Very little room to work it due to the header, engine, trellis frame and mono shock . Mark recommended a flex joint socket wrench with and extension. On my way to the autoparts store to get one.
2008 848 Track Bike
The ModFather
Duck Off
Monster Magnet
« Reply #13 on: July 19, 2012, 03:24:41 PM »
Here it is from THE MAN himself Mark Savory...
How to install Boom Tubes:
Remove factory exhaust.  Check to make sure the 10mm jet nuts (used to hold exhaust to engine studs) are good and the gaskets within the exhaust port are still there. (sometimes Ducati installed without)
Mount the rear header first.  Use above  10mm jet nuts.  I like to use a 10mm deep socket (1/4 drive) with a flex joint and 6in+ long extension -- makes it easy. (to remove as well!)   Lightly snug but not tight.
Collector slips onto rear header.  Use spring to hold in place.
Front header.  Clip into collector assembly and then slide the front into the exhaust port.  Install 10mm jet nuts from before.  Install spring.
I then check all clearances as the system can be moved left/right a small bit.
Tighten 10mm jet nuts.
Fire and idle -- check for exhaust leaks. (shouldn't be any but check on the exhaust port to head connection -- you will feel the hot air if there is one)
Put 3-4 mild heat cycles into the exhaust as the ceramic coating isn't 100% cured.  After that you can dyno, full hard throttle run, etc
Other:
1) I use aluminum hot water / head duct tape on the engine for disassembly / assembly to avoid scratching things.
2) leave the white foam cover on the exhaust until completely installed.  The ceramic coating can be scratched and this will help protect. (ditto for tips)
3) All slip joints fit perfectly when here.  Sometimes with ceramic coating the thickness makes the slip joint very tight for installation.  Two tricks:  just dab with water to act as a lubricant.  If not, then get sandpaper and sand the inside of the outer slip joint.  The material is 304 stainless and won't rust either way.
I use ceramic coating for: 1) it makes the system visually disappear; 2) you can touch the exhaust way earlier than if uncoated -- thus why internal/external coated.  So less chance of exhaust burns over the years which are no fun.
2008 848 Track Bike
seanster
« Reply #14 on: July 19, 2012, 07:02:30 PM »
Where are the pics man!!!!!!!!!!!!!  Grin
Pages: [1] 2   Go Up
