December 21, 2024, 06:45:29 PM *
Author Topic: Down shifting in a turn...  (Read 4083 times)
sgollapalle
« on: July 15, 2012, 05:18:02 PM »
Off late I have been finding myself in situations where I'm having to down shift when I'm into a turn and at a moderate lean (no knee dragging) which is creating a slight unsettling movement of the bike.. I guess the pressure I use to shift kind of straightens the bike up a bit.. noticed this mostly on right handed leans... It probably happens on lefthanders too, just hasn't registered in the brain yet.
And YES I do downshift and adjust speed to that of the turn and my skill.. I'm talking of when the person [idiot] in front slows down to a crawling speed pretty quickly..
Is this a common occurrence, or is there room to improve on the shifting.. Thoughts, ideas??
'11 M-696
« Reply #1 on: July 15, 2012, 05:28:26 PM »
leave more room between you and the other rider/driver.
S2R 800 '07
« Reply #2 on: July 16, 2012, 12:45:47 AM »
Anything done during riding will upset the bike - things done mid turn tend to upset it more.
If it's manageable or not depends on many, many factors - mostly riding skills.
PhilB
Scruffy Duc
« Reply #3 on: July 16, 2012, 06:22:15 AM »
Are you giving a bit of gas to match the revs to the speed when you let the clutch back out?  Or are you letting the clutch and tire take up the slack, thus causing engine braking to occur?  If the latter, then that's your problem.
PhilB
1993 Ducati M900 Monster "Patina" (203,000 miles, so far) -- 1995 Ducati M900 (wife's bike) -- 1972 Honda CB450 (daughter's bike) -- 1979 Vespa P200 (daughter's scoot) -- 1967 Alfa Romeo GT Jr. (1300cc) -- 1964 Vespa GS160 (160cc 2-stroke) -- 1962 Maicoletta scooter (275cc 2-stroke) -- 1960 Heinkel Tourist 103A1 scooter "Elroy" (175cc 4-stroke)
Cloner
Nah...I ain't no stinkin'
....because a mind is a terrible thing......
« Reply #4 on: July 21, 2012, 08:41:08 AM »
If you're actually worried about it, simply don't do it.  Develop your skill set to make it comfortable by fiddling about shifting at lesser lean angles until you're comfortable.  If you're not leaned hard, it's not a problem as long as you're smooth and work within your comfort zone.
As someone else mentioned, if you're uncomfortable because of your proximity to another rider you have several options.  Leave more room.  Pass before the turn.  Leave the bike in the higher gear and downshift on exit (if you're really uncomfortable shifting leaned over).
The best response, I think, is just to do what feels "right" to you!
'64 Ducati Monza 250
'00 Aprilia RSV Mille
'03 Ducati 800 SS (race bike)
'04 KTM 450 EXC
betarace
« Reply #5 on: July 21, 2012, 05:58:35 PM »
You should get all of your downshifting done BEFORE you are in a turn. It is much better to go in slow and roll on the throttle (much stabled bike) than trying to downshift while leaned over. Awful technique.
____________________________________
2006 Ducati Monster S2R 800
2006 Ducati 999S Mono Nero Limited Edition
polivo
« Reply #6 on: July 24, 2012, 07:01:55 PM »
what he said!
sgollapalle
« Reply #7 on: July 26, 2012, 07:55:23 AM »
Thanks guys for the feedback.. As I have stated in my OP, I do down shift to the appropriate gear to match the speed of the turn.. Its in scenarios when the car/SUV/Truck in front slows down way too much (like coming to 20mph, when the turn can normally be taken at over 50mph)
PhilB
I usually keep my rpms at about 6000 when I enter the turn so I have +/- 2000 on either side before I need to switch gears.. That said, When I come into these situations, I let the rpm fall to 3500 before I decide to drop a gear.. I think its in my muscle memory to give it some gas when I let go off the clutch.. Will need to consciously check the next time that I'm doing it..
'11 M-696
theprocess
'09 M696
« Reply #8 on: August 08, 2012, 01:20:23 PM »
In the situation youre describing I agree with Raux.
Otherwise, you should be setting up for the turn (i.e. body position, braking, gear selection, etc.) way before you flop the bike into the turn. All in an effort to keep the bike stable while cornering. Destabilizing mid-corner can lead to bad things.
