October 31, 2024, 10:18:21 PM
Please Help
replacing brake and clutch sline
Topic: replacing brake and clutch sline (Read 727 times)
garryc
July 21, 2012, 06:03:24 PM »
98 M600
hoping for some advice on replacing old rubber lines with braided lines.
haven't started disassembly yet as want to get everything set up first.
not sure what sort of crush washers I will find on banjoes.
can whatever is there be reused.
If they are copper do they need to be annealed and if so can someone recommend a technique for this.
If should be replaced can I use universal crush washers and of what size?
thanks
garryc
Re: replacing brake and clutch sline
July 21, 2012, 06:57:19 PM »
All you need is here:
http://www.yoyodyneti.com/Category.aspx?CategoryID=2899
Call Fred and he will set you up with the correct lines and washers. Do you
need
to replace the crush washers? No, but they are relatively cheap and you should.
973 386 0040
garryc
July 22, 2012, 01:49:00 AM »
Thanks Howie,
I already have the braided lines and I am in rural Australia so not really practical to give Fred a call.
I guess what I need to know is can i use the existing banjos and what size are the crush washers so I can source locally
thanks
garryc
Ddan
Some of my best friends are whores
July 22, 2012, 02:10:59 AM »
You can re-anneal the copper crush washers with a plumbers torch, just get them red hot and once they cool they'll be good to use
1992 900 SS,
currently a pile of parts.
Now running
flogged successfully
NHMS 12 customized. Twice. T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
