February 23, 2025, 03:40:43 PM *
Author Topic: Kickstand woes  (Read 1456 times)
chris1044
« on: July 25, 2012, 05:44:52 PM »
Stock kick stand on an S2R....when I ride over bumps the thing jiggles/comes down from the bike and slams back up.
The bolts/nuts are tight, but it's still all over the place.  I haven't taken it off the check bushings (assuming there are some), but if they're fine what's next??
I never understood why cyclecat made a kick stand...until now  laughingdp
Heath
« Reply #1 on: July 25, 2012, 09:56:14 PM »
Are the springs good too?
2007 Ducati Monster S4RT
Novelo
« Reply #2 on: July 26, 2012, 04:34:44 AM »
I would double check that spring it should a double spring one inside the other and make sure it has plenty of tention.
okboatie1
« Reply #3 on: July 26, 2012, 04:40:40 AM »
^^X2 on the spring.  inspect it pretty close to see if there is some debris causing it to bind or that one of the ends has not popped out of place. Then i would spray the sh•t out of it with wd40
Omnipotent Potentate
Personal Pretext
« Reply #4 on: July 26, 2012, 08:10:38 AM »
The cycle cat stands were offered at different lengths, and well look better.
But +whatever to checking the spring.
chris1044
« Reply #5 on: July 26, 2012, 05:46:55 PM »
Yep, that would be a problem.  I have ONE spring on mine.  Spring has decent tension...I hadn't look really close so didn't notice another location for a spring.
It is possible that it's a spring inside a spring, and if that's the case IDK if mine's got both springs.
Thanks for the posts...I'll take a look this weekend.  waytogo
chris1044
« Reply #6 on: July 30, 2012, 03:16:43 PM »
Well,
Checked the stand for two springs....and they're both there. One inside another as I thought.
It's got some "side to side" wobble if you move the end of the kick stand left/right like the pivot has a worn bushing or something.  That's my next point when I've got time.
Or I'm looking for heavier springs/aftermarket.
