low handlebar setup on a new monster
Started by Barney, July 27, 2012, 11:17:19 AM
Barney
in doing a little searching around, it looks to me like most go with clip ons to get a lower bar setup...I actually like the bar on my 1100 evo and I dont want to be laying on the tank, so I was wondering if anyone knows of a lower riser for the top triple - i've seen risers that are higher than stock, but nothing lower as far as I know...seems to me you might be able to get ~3/4-1in lower bar height out of different clamps...
i guess clipons are an option but i really do like that wide bar, and they'd be less fun to install... [Dolph]
12 M1100EVO
09 KTM 200XC - sold. I cried.
70 Honda 450 Scrambler
jongunz
I used the Rizoma risers from monsterparts.  I didn't use the circular disks that go under them though but it gives a slighter lower bar height than the stock riser.  Here's a pic.
jongunz
One more... I've been happy with them.
Barney
good to know!  I didn't realize they're not all one piece - did you start with the 42mm or the 60mm?
good looking ride by the way
12 M1100EVO
Mhanis
Shift, this is memory so I refuse to accept responsibility for accuracy.
I believe the Evo comes with a higher riser than the earlier M1100/1100S. If that is right you might be able to replace yours with an oem part from a non-evo bike. Just a thought.
Mark
Pete Townshend
wannabfast
i believe the 696 1100/s has the lowest risers out of the box, the 796/1100evo is higher by a few mm
jongunz
The rizoma rises I used were the 42mm.  They're supposed to replace the 696 riser which is lower than the 796.  The little disc that I opted not to use was more or less a finishing piece and I thought it was supposed to close the gap because there is a little metal nipple that sticks up from the triple but when I installed with the disc it actually had a gap underneath it.  I tried drilling it out to fit around the nipple but no luck.  I didn't have a drill press so I essentially jacked them up trying to make the holes bigger.
theprocess
Quote from: jongunz on July 27, 2012, 01:22:53 PM
Looks nice.  [thumbsup]
The earlier 696/1100/1100S had lower bars than current models but this set up looks a tad lower (based on what I can see from the pics).
