January 07, 2025, 11:09:26 PM
Please Help
Whiney 695
Topic: Whiney 695 (Read 1819 times)
myfirstduc
Whiney 695
June 27, 2008, 08:02:22 AM »
Lately i have noticed my 08 695 makes a high pitched whine. This happens the majority of the time regardless of, brakes applied, throttle on, rolling, stopped, etc..
I can make no rhyme or reason for it.
Also, it is stock.
Anyone else have any idea?
Thanks
oh no...a drug dealer is here!
Re: Whiney 695
June 27, 2008, 12:21:06 PM »
Quote from: myfirstduc on June 27, 2008, 08:02:22 AM
Also, it is stock.
Thanks
Is it the same sound as you hear immediately after turning the key on?
If so, that's the fuel pump.
acalles
Re: Whiney 695
June 27, 2008, 12:34:07 PM »
Mine has started to do this also in the 50-60mph range, goes away at higher speeds and starts up slowly around 25..
I'm gonna check chain tension.. its the only thing I can think of
other then it might be normal, but I'm new to the bike so I don't know.
I've cleaned and lubed the chain, all seems fine.
SKOM
Upside Down Canuck
Re: Whiney 695
June 27, 2008, 12:53:02 PM »
I can hear my fuel pump on my S2R. I think it's normal. Getting louder pipes might help
"Die gefährlichste Weltanschauung ist die Weltanschauung derer, die die Welt nie angeschaut haben."
— Alexander Von Humboldt
teddy037.2
Re: Whiney 695
June 27, 2008, 01:13:25 PM »
I only hear the pump when I turn the ignition switch on...
or, y'know... +1 on the pipes mod
Re: Whiney 695
June 27, 2008, 01:38:33 PM »
Possibly the belts or tensioner/idler rollers.
But it really is dependent on exactly when it's happening, and that's not clear from the OP.
OT
Still Sweeping.....
Re: Whiney 695
June 27, 2008, 05:11:32 PM »
My '04 M1000 has always done it, too; frequency changes with engine speed.....I really don't "notice it" much after 11k+ miles.
Last Edit: June 30, 2008, 07:07:40 AM by OT
scott_araujo
Re: Whiney 695
June 27, 2008, 05:37:45 PM »
Quote from: Speeddog on June 27, 2008, 01:38:33 PM
Belts that are too tight will make a whining noise. If it's the belts the whine should follow the engine speed.
Scott
VeryMetal
Re: Whiney 695
June 30, 2008, 10:21:43 AM »
I probably don't know what I'm talking about but I had a friend have the same problem on a different bike, turned out it was the intake, in which case there's not much you can do about it short of modding it, which isn't a bad idea, especially if you have pipes.
2002 Ducati Monster 750ie Dark
2005 Monster S2R Dark
myfirstduc
Re: Whiney 695
July 01, 2008, 07:01:41 AM »
Thanks for all the help, sorry i have been out of town and just now see all the replies.
So far i am going with it is normal, and will have it looked at when i hit 7500 miles.
I totally agree on the louder pipes
, they are on the list, but not in the budget yet
Thanks again.
