November 27, 2024, 12:33:04 AM *
Author Topic: Soft wet clutch springs Monster 620 ie???????????????????????  (Read 4244 times)
jamie2548
« on: July 31, 2012, 02:37:14 AM »
Hi guys.
Dont know if this has been talked about or not?
My wifes 06 620 has,what we were told when we bought it off the previous owner, has soft clutch springs in it , his gfriend had them installed to prevent severe compression lockups when she went down through the gears.
Its ok for my wife but I am going on a big ride (for me its a big ride) in November up the snowys and down to Mt Buffalow and back to the princes hwy and home and when Im on it and give it a gutfull it slips.
I am wanting to put the normal springs back in. It seems basic enough as I am mechanically minded and experienced in building performance motors for cars so thats no prob . BUT what springs am I looking for (standard 620?) and the best place to by them online. Do I need to get new bolts and cups aswell??
Any infor would be great thanks
Betty
« Reply #1 on: July 31, 2012, 02:56:23 AM »
Hey Jamie, welcome aboard.
Can't really help you with the pulling apart and putting back together stuff 'cos I'm useless. But I've never heard of anyone changing the clucth springs on a 620 ... they have about the lightest clutch pull going around - even lighter though with a larger diameter clutch slave I s'pose.
An '06 should have the APTC 'slipper' clutch so I don't undertsand why it would need to be modified to prevent compression lock-ups.
You'll have to wait for someone intelligent to answer your questions though I'm sorry.
Oh and your November trip through the Snowies won't include Ducati Turismo will it?
S2R 800 '07
« Reply #2 on: July 31, 2012, 03:05:37 AM »
Maybe the easiest way to reach your goal would be to add a washer under or over the spring...
That will tighten them up and it's a free mod.
If you still want other springs - the stock from a 620 are the same as for the S2R 800.
Are you sure the current springs are softer? Don't know which bike that would be from. Maybe two springs were removed?
Minimum spring length is 36.5 mm. Liquid gasket on side cover. Grease and torque spring bolts to 5Nm.
S2R 800 '07
« Reply #3 on: July 31, 2012, 03:09:09 AM »
I'm surely more intelligent than Betty, but that doesn't mean I'm intelligent enough so double check everything said Grin
jamie2548
« Reply #4 on: July 31, 2012, 03:17:32 AM »
Thanks Betty and Stop waytogo
yeeh its all a bit suss when we bought the bike. A friend of mine says there is no such thing as a "soft" spring as you guys said.
Not sure its got a slipper clutch either as I thought they were a race style clutch and I doubt there is one in there. Spose the only way to find out is pull it off?
 Nah Betty its just a ride with a few mates.
S2R 800 '07
« Reply #5 on: July 31, 2012, 03:30:54 AM »
Doesn't matter if it is an APTC or not (,but it is) because the spring considerations are the same.
jamie2548
« Reply #6 on: July 31, 2012, 04:13:21 AM »
Thanks stop. That helps. So I am presuming either the clutch plates are worn or the springs are stuffed ?
« Reply #7 on: July 31, 2012, 07:10:08 AM »
It's possible the plates are worn out... How many miles on the bike?
I've had a couple customer bikes with the APTC clutch suffer slippage with good plates.
I've found some shims that will fit the rather cramped quarters, and put enough more preload on the springs to get the clutch to stay hooked up.
jamie2548
« Reply #8 on: July 31, 2012, 12:41:34 PM »
It has got 20k on the clock so I presume thats enough time to warrant worn plastes. it just confused me how the seller said he put soft springs in? Now even more when I realize it has a slipper clutch in it. I wonder why he bothered to do anything with it.
I am purcasing new plates and springs anyway to be sure. then I will open her up and have a look.
Thanks again for all you help. I will keep you posted on my findings  waytogo
« Reply #9 on: July 31, 2012, 12:58:38 PM »
Shims 12mm ID x 18mm OD x 1mm thick, use 2 on each spring.
I SuperGlue 'em to the washer, as they've got to stay in place to fit around the post.
dragonworld.
I can make like a tripod with my.....
« Reply #10 on: July 31, 2012, 01:21:27 PM »
Not unheard of to have a clutch start slipping at that mileage, but I'd say its been abused!! My old 750 has 92,000k on the clock and it still has the original clutch assembly in it and works fine!!  waytogo
I'd just throw a set of springs at it, they are cheap! Give the plates a clean and measure their thickness to make sure they are servicable and jobs done!! Easy job!  Dolph Dolph
kyle
« Reply #11 on: July 31, 2012, 04:13:52 PM »
My 620 has 45 on the clock, slips in 4th and 5th when the oil temp is under 50 degrees.. kinda annoying..
Betty
« Reply #12 on: July 31, 2012, 04:43:48 PM »
Oh and I just remember reading something 'way back when' about the type of oil being used ... and it causing slippage under certain circumstances.
If my recollection is correct, can someone with the technical know-how post their opinion?
dragonworld.
« Reply #13 on: July 31, 2012, 04:49:54 PM »
Yep, yep!! Remember that one!!
Oil viscosity, oil additives, can and do play a part in a clutch slipping, along with wear of course!  Grin
jamie2548
« Reply #14 on: August 03, 2012, 02:28:58 AM »
Cheers everyone.
I had a email from the previous owner saying the springs were getting on a bit and were going to be replaced. Bit of confusion on my behalf. Ya get that though. So i am going to change the springs and see what happens. Also will get some new clutch plates because they are already on order from the US.(along with oil cooler and KN airfilter.
Thanks for all your advice waytogo
