Dereflectorization.
Started by VeryMetal, June 27, 2008, 11:57:04 AM
VeryMetal
Not sure if this is exactly a 'tech' question but..
What is the easiest way to remove the stunningly good looking reflectors from the forks of my/ our bikes? I've heard a heat gun is the best way. Any other suggestions or advice for the heat gun trick?
2002 Ducati Monster 750ie Dark
2005 Monster S2R Dark
Ducatiloo
Heat gun or even a hair dryer, then use hair spray or goo gone to get rid of the extra tape that is left over.
750 SS 01    800 S2R 05  Aprilia RST 1000 futura
mangeldbug
What I learned from my reflectorectomy is that the fork tube metal is extremely soft.  I used a soft plastic scraper (like for applying tile grout) and was very gentle about it (I thought) and I still got a few knicks  :(
Brake cleaner does a great job at removing the sticky stuff, but be really careful about not getting it anywhere near your wheels or other painted parts.
2002 M750Si.e. "Senna" - Meravigliosa, Mera for short
2017 390 Duke Commuter
2001 XT225 Zombie Assault Vehicle
1987 YSR50 #116 race bike
Take it to a Duc get together and let a drunk Statler and DP near your bike.
Seriously, just twist it like a wing nut. Thumb on the top and close to you, fingers on the bottom of the far side. Twist. *snap*
Look, Ma! Nekkid forks!
Folks have had good results with waxed dental floss.  Wind it round something on either end like a garrote and slice it off.  A little goo gone will help clean it off.  And you don't have to worry about your paint if you use that over brake cleaner.
OverCaffeinated
Goldeneye
+2 on Twistin'  [thumbsup]
Been ignoring them reflectors until I saw your post...
Walked out to the garage, snap and snap.  A little goo gone on a paper towel and I'm done.
Left side took two hands, but all in all not too bad.
teddy037.2
dental floss is the #1 trick for removing badges from your car's trunk lid  ;D
but I found that after having the bike sit in the sun for a while, the twisy action works just fine [thumbsup]
c_rex
"reflectorectomy" - heat gun or hair dryer should do it.  be mindful of the paint and don't set a heat gun on full tilt if that is your weapon of choice.  To get the remaining gooey bits use a bit of 3M adhesive remover (or similar solution) followed by a light wash of dishwashing liquid soap and water.  don't leave your sticky remover on the paint.
OverCaffeinated
I did do mine right when I got my bike. The reflectors get harder to take off as time goes by.
Fresh Pants
+1 on mental floss, then clean up the residue with goo gone/equal or WD40.
Bwooooooahhh
Braaaaaaaappp
i dont get the whole brake fluid on paint kills thing. I tried using brake fluid to strip some paint of my rims and it didnt work. :P LIES ALLL LIES!!!!!!
herm
Quote from: dark800 on June 27, 2008, 12:16:47 PM
+1 on just twistin off.
if you ride for a bit with a stock clutch (no slipper) this should be easy.
for those who cant handle the heavy clutch (for whatever reason) vice grips carefully applied will take care of the twist off reflectors. [thumbsup]
No more Monster.
teddy037.2
Quote from: herm on June 27, 2008, 08:16:37 PM
[laugh] [laugh] [laugh]
hey hey you there watch your mouth, you try holding that mother sucker in for 20 minutes without letting go. [bang]  ;D
