February 23, 2025, 01:38:49 PM *
Author Topic: 696 low beam - Osram Rallye 65W Ultra High Output?  (Read 3487 times)
theprocess
'09 M696
« on: August 01, 2012, 06:38:33 PM »
Anyone have an Osram Rallye 65w Ultra High Output (H7) installed in a 696 low beam? Any issues using stock wiring? The stock bulb is 55w so just want to make sure the 65w bulb won't fry the stock wiring.
http://store.candlepower.com/osraulhiouh7.html
« Reply #1 on: August 01, 2012, 11:15:04 PM »
I'm using a 55/65 lo/hi combo and haven't had fried wiring on harness
theprocess
'09 M696
« Reply #2 on: August 03, 2012, 06:28:36 AM »
Do you ride with your hi beams on during the day?
« Reply #3 on: August 03, 2012, 07:42:51 AM »
no
the hibeam are just for running at night on barren roads
theprocess
'09 M696
« Reply #4 on: August 03, 2012, 07:48:50 AM »
Thanks. Got it. I just wanted to know if you had the 65W bulb constantly drawing/on. I know some people ride during with hi on during the day to be more visible. In this case it would be a proxy running a 65W lo and any negative impact on the stock wiring. But not the same in your case.
scooterd145
« Reply #5 on: August 03, 2012, 08:52:47 AM »
I was running "Hella" low beam and and high beams. The wiring got hot and started melting so I went back to stock. I can't remember which one for sure started melting. I always ride with my high beam on Day or Night. does not seem to bother drivers and it is REALLY hard to see with just the low beam on.
Scott
theprocess
'09 M696
« Reply #6 on: August 03, 2012, 10:58:31 AM »
Hmm...according to this Hella 65W bulb is the Hyper (all the others are 55W which technically should be fine).
I'm leaning towards sticking with a 55W spec bulb. Philips Extreme Power get great reviews.
Duc796canada
My first Ducati and road bike!
« Reply #7 on: August 10, 2012, 05:49:09 PM »
I use the Sylvannia Ultra and Extra vision, 55W. I do ride with my hi beam on during the day as well, if it is cloudy, I just use the low.
796 Red Monster(sans ABS)
Viz-Tec Supabrake II
15/41 gearing(AFAM quick change sprocket)
PC V, NEXTUP QS.
2006 Suzuki GSXR 600 track bike(I know...not a Duc...some day)
