Which Regulator??
Started by xsephirot, August 04, 2012, 03:49:16 PM
xsephirot
So my regulator burnt out. Should have listened to booger and done it earlier  [roll]
Not sure which one to go with.
Rick's Motorsport one (I'm assuming this one is compatible with a s2r 800): http://www.ebay.com/itm/Ricks-Motorsport-Hot-Shot-Regulator-Rectifier-Ducati-748-750-996-998-Monster-ST-/370636180818?pt=Motorcycles_Parts_Accessories&hash=item564ba34d52&vxp=mtr#ht_3001wt_906
or one from Ca-Cycleworks: http://www.ca-cycleworks.com/esr537
Any recommendation guys?
Additionally looking to mount the regulator under the bike suck as the TPO kit. However that one also removes the breather thingy. Is there any reason why I can't just mount the new regulator under the plastic and screwing it on?
I put a Rick's in my M900 years ago...don't remember how many.
Still ticking. [thumbsup]
xsephirot
Quote from: ducpainter on August 04, 2012, 03:51:22 PM
Thanks ducpainter!
I have a dilemma however. How do I both keep the crankcase breather while simultaneously mount the regulator underneath the bike? This is on a s2r...
ducatigirl100
I got the Ca-Cycleworks  and it works great .. very good quality and very well done piece [thumbsup]
[popcorn]
xsephirot
Where did you mount yours ducatigirl?
ducatigirl100
Quote from: xsephirot on August 04, 2012, 09:29:38 PM
At the front.  where it supposed to be .  I  would never attempt to put it elsewere  considering the reason that I change it was because it literally caugth on fire.   :o :o  I stop by the side of the road and threw some dirt at it !    [bang]      those thing get hot !!give it some air
it burn half of all the wiring in front of the bike ( I add to get a new wiring loom  [roll])
thus... after changing the regulator the bike ran allot better. acceleration is smoother.
booger
You want whichever one has the MOSFET circuitry. It has to do with how the excess energy is dissipated, stock one is not ideal. Heats up & fries, and the stock mounting location doesn't help.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
Roaduser
http://roadstercycle.com/Shindengen%20FH012AA%20Regulator%20upgrade%20kit.htm
i got one of these and couldnt be happier. barely gets warm and 100% trouble free notoring ever since.
xsephirot
Quote from: Roaduser on August 05, 2012, 10:31:45 PM
Awesome thanks! I like how it comes with everything you need. Is there any reason to use the 30A fuse to the battery? I've heard it is possible to do without it (less connections = less chance of failure parts)
Additionally, did you move where you mounted your regulator?
suzyj
Second the Shindengen one. That's the route I'm taking with mine.
I've also moved it forward to where the battery used to be. Not that that's likely to be any use to you, of course.
xsephirot
Quote from: suzyj on August 06, 2012, 03:24:49 PM
Please do elaborate? Did you go with a smaller battery such as the shorai and then mounted it next to it?
suzyj
#11
Quote from: xsephirot on August 06, 2012, 03:41:13 PM
A smaller battery, yes, but not the Shorai.
Here's a photo of the general layout - a little out of date and with the standard rectifier in there rather than the Shindengen, but it gives the overall idea:
This photo shows the Shindengen rectifier mounted, but not on the bike:
http://www.ducatimonsterforum.org/index.php?topic=56614.0 has the whole saga :)
xsephirot
#13
Quote from: koko64 on August 06, 2012, 09:57:33 PM
That is so tidy.  [thumbsup]
+1 Thanks for the pics Suzy!
I must say that these 2 pics look absolutely horrifying. I want to reroute alot of wires too (and the oil lines) but this wire loom looks and feels just like  [bang] [bang] [bang]
Privateer
Quote from: xsephirot on August 04, 2012, 03:49:16 PM
Quote from: Privateer on July 06, 2012, 11:21:07 AM
flipped my rectifier and got rid of all the plastic crap under there.
I dont think you'll be able to easily mount the rectifier under the plastic tank.  I removed the tank, stuck a small filter in the end of the outgoing breather hose, zip tied it to the frame, and plugged the airbox with an old bar end plug.
