November 30, 2024, 03:24:53 AM *
News: Please Help
Author Topic: Lock it  (Read 2352 times)
jamie2548
« on: August 04, 2012, 07:40:32 PM »
Hey all.
You been such alot of help lately I thought I would ask some more info.
One question is . What brand "Locktite" is the best? I have used locktite on vehicle engines that doesnt want to let go when pulling motors back apart.
The other is . What sealant is the best for the clutch cover on the wifes monster. It has no gasket so I was wanting to know what brand would be the best to make a good seal?
cheers. waytogo
FIFO
Doing the latter
« Reply #1 on: August 04, 2012, 09:25:18 PM »
 I use loctite 222 ,basically because that's what i had, Roll Eyes  reading the tech sheet though looks ideal for aluminium and low strenght, not to strip out the aluminium on removal, though, i wouldn't use locktite on any of the engine crank case. Huh?
http://www.loctite.co.uk/cps/rde/xchg/henkel_uke/hs.xsl/fullproduct-list-loctite-4995.htm?iname=Loctite+222&countryCode=uke&BU=industrial&parentredDotUID=productfinder&redDotUID=1000000I7EX
Ducati  recomend Three bond sealant which is a silicone based,i think Ducati sell it, have seen it on ebay and a bike shops, MCAS, Though i don't think there is anything special about, just a different American name for something  we can get  here,  Wink
http://www.threebond.com.au/distributors.htm
http://www.ebay.com.au/itm/THREEBOND-THREE-BOND-LIQUID-GASKET-MAKER-CEMENT-SEALER-1104-200g-/140754326018?pt=AU_LawnmowerAccessories&hash=item20c59c9202
I use permatex ultra grey RTV silicon gasket maker, can get it at autobahn, Repco, and most auto shops. Wink
Used on all my case covers on the bike and car and 4wd, no problem  waytogo
http://www.permatex.com/products/automotive/automotive_gasketing/gasket_makers/auto_Permatex_Ultra_Grey_Rigid_High-Torque_RTV_Silicone_Gasket_Maker.htm
« Last Edit: August 05, 2012, 01:30:22 AM by Rob s » Logged
suzyj
Does my bum look big on this?
« Reply #2 on: August 04, 2012, 10:58:19 PM »
Loctite comes in colours - different colours have different strength. Purple is lowest strength, followed by blue, followed by red. Red needs heat for disassembly.
In addition to the Permatex sealant mentioned by Rob, there's also Yamabond, Hondabond etc, which is all the same stuff.
If you want the best advice on how to sort oil leaks, talk to a BSA owner Tongue
Betty
« Reply #3 on: August 04, 2012, 11:22:43 PM »
Any chance you learned ones could provide the rest of us with some idea of when to use loctite (ie. is there somewhere you shouldn't use it) and what flavour you should use for different applications?
dragonworld.
I can make like a tripod with my.....
« Reply #4 on: August 04, 2012, 11:43:32 PM »
Yep, or basically ANYTHING British!!  Roll Eyes They invented the "total loss" oiling system! In one end and out the other! (Generally NOT through the combustion chambers!!  laughingdp )
BSA = Bits Stuck Anywhere!!
But mostly Bastard Stopped Again!!  applause Roll Eyes Evil
jamie2548
« Reply #5 on: August 04, 2012, 11:51:51 PM »
Thankyou very much. Much appreciated. Oh and Dragon laughingdp
suzyj
« Reply #6 on: August 04, 2012, 11:52:37 PM »
I generally don't use loctite. For most of the stainless M6 cap screws threading into aluminium (stator cover, clutch cover, etc etc) I just put a little dab of grease on the threads to prevent galling.
If it's a screw or nut that's likely to get hot (valve inspection covers, headers, calipers, etc), then I'll substitute copper anti-seize for the grease.
I used blue loctite on the rotor bolts, after cursing the bastard in the factory who used red loctite there. I plan on using a dab of blue loctite on my cam pulley nuts when I get around to reassembling my heads.
The only place I know people use the red stuff is crankshaft nuts and clutch basket nut.
Betty
« Reply #7 on: August 05, 2012, 12:08:12 AM »
Fanks Suzy.
Of course I have absolutely no idea what those parts are you are talking about.
FIFO
Doing the latter
« Reply #8 on: August 05, 2012, 12:23:42 AM »
Brad black would probably be the best man for that info.
Loctite can be identified buy a white power residue and or a coloured  plastic looking stuff left on the thread of the bolt after removal.
So if it was on the bolt on removal put loctite back on it when you put it back together.
Though from my limited experience with Ducati. Tongue
Ducati use loctite on the brake rotor retaining bolts,and rear sprocket nuts (DSS)the low strength 222 purple is ok for that application.
Loctite is used through out the engine, gearbox assembly, 271 red loctite would be more suitable there.
Or as per the workshop manual Tongue
 *Use loctite only on steel or stainless steel, if used on aluminum it would have the possibility to strip out the aluminum thread on removal.
ie the crank/engine cases don't use locktite, i use anti seize here and ather numerous threads.
*Note Ducati use a lot of stainless steel thread inserts in aluminum, ie the rims were the brake rotor mount. then loctite can be used.
If in doubt don't use  loctite just carry a good set of tools/ allen keys to tighten every thing up as it rattles off.  laughingdp
And What Suzy said,beat me to the post  waytogo
« Last Edit: August 05, 2012, 12:26:35 AM by Rob s » Logged
Betty
« Reply #9 on: August 05, 2012, 01:01:12 AM »
Yep it was the rattling off thing that I am concerned with ... I just wanted to know which things are safe to glue down.
Thanks
garryc
« Reply #10 on: August 05, 2012, 03:53:47 AM »
If you go for a ride on bevel drive and nothing falls off you haven't ridden far enough.
loony888
"I WAS GOING HOW FAST, OFFICER?"
« Reply #11 on: August 06, 2012, 02:12:19 AM »
Thanks
if you have a manual on the torque settings page it will tell you where you use what grade of loctite and also where to apply grease to a thread. I only loctite where the manual says and on anything that doesn't use it i use a small amount of copper anti seize, this practice alone saves wellnuts from tearing up saving a small fortune over time.
It's funny, the factory manual is virtually useless for the home mechanic, it's either way too technical and discusses special tools or it's overly simplistic with dodgy translations. I rely on the exploded parts diagrams for reassembly most of the time.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
Wells
« Reply #12 on: August 06, 2012, 06:07:22 AM »
waytogo
2005 M620
Hi. I’m Troy McClure. You may remember me from such self-help tapes as “Smoke Yourself Thin” and “Get Some Confidence, Stupid!”
NYTimes: "...highlights of his global tour include encounters with Nelson Mandela, an 800-year-old demigod and a dildo collector."
GK
« Reply #13 on: August 06, 2012, 05:58:22 PM »
I bought a new clutch cover gasket last week for just over $10.
Much better than any goop you might use.
GK
2001 Ducati  Monster 900S ie
Gone but not forgotten!
loony888
« Reply #14 on: August 07, 2012, 01:22:09 AM »
the only "goop" i use is the ducati threebond, as used in place of most paper gaskets these days
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
