Best Functional Replacement Mirrors
Started by FiveG, August 12, 2012, 10:40:58 AM
FiveG
I'm looking at options for replacement mirrors for my M1100 Evo that work best for actually seeing behind (and to the side).   Not willing to do bar ends.
There's a bunch of Rizomas I know but not sure which are most functional.
Suggestions and comments on what you've used would be appreciated.
"I hope you succeed, but no matter what happens, Godzilla will live."
"Steve Martin," Godzilla (1985)
Large surface area + convex = good. Preferably the surface area should be large at the ends.
Position as far out as logical for you. If necessary by mirror wideners, but not if you are a medium/small rider.
If you (by using wideners?) are able to see straight behind you, there will be less dead angle view - can't have both.
Height is also a consideration - easier to see without taking your eyes away from traffic if they sit high.
I've been very happy with my Rizoma Impulsive [thumbsup]
The Ducati Viper mirrors look good too...
slowkitty
Limiting to non-bar ends, the Rizoma series seems good although I think they are pricey.  I really like the Dynamic but price is a factor:
There are however knock-offs on eBay that are cheaper, although I do not have any inkling about the quality difference.
bob795
I don't know if it's the best or not, but I like my Rizoma Dynamic mirrors. It's narrower (and the position is lower) than the stock mirrors, so it won't tick cars' mirrors when lane-splitting, and I can see better with the rizoma. Just take your time to set it right (adjust the stem angle, height, backward or forward and the mirror itself) when installing it.
2011 Husqvarna TE 630
2012 Monster 795
2002 Sportster 883/1200 (sold)
CraigBa
Just bought a pair of these off eBay for my Monster and they don't look bad at all. Very impressed with the quality.
http://www.ebay.com.au/itm/190683004357?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_3407wt_1165
"It is a thousand times better to have common sense without education than to have education without common sense".
Ducati Monster S2R
Husqvarna TE449
1983 YZ250K (VMX)
Hyosung GT650R race bike.
Best mirrors I ever used for actually seeing what's behind you were Rizoma Class Retros..... but they are barends (large ones) but barends nonetheless.
duke8
I've had the rizoma dynamics, and whilst they look great, I couldn't see much, other than my arm... That said though I have very low clip ons which probably effect the visibility somewhat.
I sold those and got the class retros, they were far better, great visibility and they look bad ass.
I just put crg's on my new bike, and I like them the better than the rizomas. Better visibility behind me and awesome adjustability.... Again, bars ends though.
'06 S4RS
thought
If you are going for mirrors to actually see what's behind you it's pretty rough to rule out bar ends.  The best mirrors for that are probably the CRG hindsights.  With them on you can easily see behind and to the side of yourself with both mirrors.
Any particular reason you wont do barends?  Most standard non barend mirrors tend to not work as well as barends simply due to the physics/placement involved.
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
Bar ends on clipons especially zero rise... are a lot of work. you have to make a full head movement to use them.
That being said.
If you can find mirrors that are fully adjustable on height and was as fore/aft, and with a longer shaft, you can push them all the way out almost as far as bar ends and higher in your forward vision.
This is what I have now.
and compared to
thought
Ah, I can see that being pretty annoying on clip ons.  Thought it was for a stock m1100evo.
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
sofadriver
Quote from: Raux on August 13, 2012, 07:25:25 AM
It's even worse when you wear bi-focals!  ;D
Mike in Tacoma
'08 S2r 1000 - Red on Red
'96 900 SS/SP
IBA 38181
JEFF_H
If you are looking at Euro mfrs (like Rizoma)...look for mirrors that are listed as 'e-marked'.
this is a EU standard like DOT that the parts are approved for road use
the 'e-marked' mirrors will be larger and more functional than the non-e ones
jeff h
monsterparts
roggie
... to one for the Diavel
http://www.ebay.com/itm/Side-aftermarket-Mirrors-Ducati-Diavel-Monster-1100-696-795-2010-2011-2012-/271024448508?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item3f1a50e3fc#ht_2910wt_1159
[/quote]
I think those are more of a 696 knock off.
I have a set of diavel mirrors (came with my bike) and they were really no better than stock.
Also keep in mind that knock off supplier is shipping from hong kong so expect a little more of a wait if you use standard shipping. And it may create more of a hassle if you need to return or exchange.
That being said I did just order a pair of CRG bar end knock offs from them and they do the job ok. The set I ordered doesn't tighten into the end of my bar that well but for now I will live with it.
Good luck !
FiveG
Quote from: thought on August 13, 2012, 06:04:13 AM
My perception has been that they increase the bike width.  Perhaps I'm wrong?
