monster evo aftermarket exhust ecu
Started by acaa, August 21, 2012, 02:28:03 AM
acaa
Does anyone own the new 1100 EVO, If so, what type of AfterMarket Exhaust have you installed ? i have orderd one from shift-tech
and did it require replacing the stock ECU for the Racing ECU or a ECU reflashing ?  I know the Termignoni comes complete with everything.
what should i do now? get a new ecu and air filter? and what about duc.ee? does it help?
for normal ops if you just replace the exhaust you dont need the ecu mod
if you mod teh filter and airbox then you need it
the duc.ee is needed if you remove the exhaust valve
acaa
Quote from: Raux on August 21, 2012, 08:55:19 AM
thank you very much , this is my very first bike ,i just know so little about it .my friend told me that i have to replace the exhust , air filter and ecu all together to make it work ,and i did as he told me to , i have got a exhaust (silp on ) and  a k&N du-9608 airfilter ,  but when it comes to ecu, i am just comfused , what should i do? should i get a new one ? if so where can i get it , or what kind of brand or product should i looking into?
U can get a reflash or add a powercommander five
Check out the sponsors
DucRipper
#6
Competition Werks M1100 evo GP slip-on + Bazzaz Z-Fi + performance air filter = one growling mean duc!  Not that there was a lack of HP before, but there was a very noticeable difference after the change.   [cheeky]
Good luck!
I guess I should also add that the stock ECU stays.  The Bazzaz unit piggy backs the stock ECU as a sort of override unit.
