February 05, 2025, 12:00:57 PM *
Pages: [1] 2   Go Down
Author Topic: wreck help  (Read 3544 times)
take risks
She gagged on my
you can go faster
« on: August 21, 2012, 10:41:33 AM »
So I went down Friday the 17th. Full gear and thank goodness. I still managed to lose a significant portion of my index finger. As that heals I am addreessing my bike repair. The biggest concern is the rock I took to the engine.
Can anyone give me a clue about what I am in for?
These are some pics of the engine case. I drove it for almost 2 hours after the incident.
It may be leaking oil very very slowly. If you touch it, you'll get oil on your finger, but no stains on the ground.
Oil is about half full in the sight glass after sitting for 2 days.
Also the fork seals were almost at the bottom of the fork.
Thank you.
« Last Edit: August 21, 2012, 10:48:24 AM by take risks » Logged
2000 VFR 800 - wrecked
2007 Ducati Monster 695
Dirty Duc
I'd rather be an anti-
« Reply #1 on: August 21, 2012, 11:11:28 AM »
One of these
http://cgi.ebay.com/ebaymotors/Ducati-alternator-cover-puller-749-999-monster-1098-748-/260422256251?pt=Motorcycles_Parts_Accessories&hash=item3ca260467b
and one of these
http://cgi.ebay.com/ebaymotors/Ducati-Monster-M620-Alternator-Engine-Cover-/320749915902?pt=Motorcycles_Parts_Accessories&hash=item4aae2f4efe
Omnipotent Potentate
Personal Pretext
« Reply #2 on: August 21, 2012, 11:18:59 AM »
Thank you.
The oil seals on the forks are still in place - or they would have bled out all the oil on the spot. What you're probably seeing is the dust seals. They are the outer most and just press fit. The oil seal is a bit further in, and retained by a spring clip.
Check the dust seals for damage. If there's none, ensure everything is clean in the cavity where they sit. If that's all clean, work them up the slider and press them back into place.
As noted, you'll need a new generator cover - definitely got a leak there.
heal quickly.
MikeZ
« Reply #3 on: August 21, 2012, 11:21:37 AM »
You rode for 2 hours after losing part of your finger?
Glad you weren't hurt worse and the bike didn't come out to back either
I had a crack in that same engine cover and found a replacement on fleebay.
I'm not that mechanical and I managed to replace it myself.
Wasn't that difficult at all except keeping the gasket in place while putting it all back together.  I was told it's easier to use a gasket then use the gasket glue (or whatever you want to call the gasket material that comes in a tube like caulk) so that's the route I went and it worked out well.  No leaks in 2 years since I put it all back together.
take risks
She gagged on my
you can go faster
« Reply #4 on: August 21, 2012, 11:59:33 AM »
@Dirty Duc
Thank you for your help. The link to the remover illustrates your genius.
@Slide Panda
Perfect. I will check that out, great thoughts. You are awesome.
@MikeZ
Yes, I rode an hour to the volunteer fire station where they didnt do much (Ice pack and 4x4). Then forty minutes to the hospital, and they helped a lot. For some reason they did not reattach the tip. Infact my buddy pulled it out of the glove as I was discharged. I threw it away. Then rode 30 minutes to my buddies house. So I guess it was over 2 hours at speed.
ATGATT. It should have been a lot worse.
The oxycodone is definitely impacting my thought process.
Cheers to everyone.
« Last Edit: August 21, 2012, 12:05:54 PM by take risks » Logged
MoltoVeloce
« Reply #5 on: August 21, 2012, 12:35:35 PM »
 Shocked
wow that sucks man. I am glad you are sorta ok.
They probably didn't reattach it because they couldn't find it if it was still in your glove after you were discharged.
take risks
She gagged on my
you can go faster
« Reply #6 on: August 21, 2012, 01:24:28 PM »
It went something like this except I came out from shade and got hit by sun and lost the road.
Good times.
Kid crashes BMW into rocks (2012)
glbrto
« Reply #7 on: August 21, 2012, 01:34:51 PM »
Glad to hear you could at least walk away from that.   Undecided
narrowlanes.net
Feral 859
« Reply #8 on: August 21, 2012, 02:16:52 PM »
Good times.
 Roll Eyes bang head
justinrhenry
Super
weeeeee!!!
« Reply #9 on: August 21, 2012, 02:42:44 PM »
Good times.
hahahahahahahahahahahahahahahahahahahahahahahaha
_____
2013 Honda CB1100D
2006 Honda ST1300
2003 Ducati Monster 620ie
Greg
« Reply #10 on: August 21, 2012, 02:45:50 PM »
Roll Eyes bang head
Could see that one coming from the way just from his driving technique.
2012 M1100 Evo with Termis
1KDS
« Reply #11 on: August 21, 2012, 02:48:25 PM »
Good times.
Hopefully that was a closed road (i'm sure it's not) or he could have easily killed someone else, complete disregard for the double yellow and total lack of skill.
Every bike I've ever owned.
gOoIe B
« Reply #12 on: August 21, 2012, 03:37:33 PM »
^^^ Thats the big difference here.  It's bastards like this that are always on my mind when I want to have fun on a twisty backroad, because I've already had so many damn close head-on encounters with these blatantly lazy sloppy asses coming through a curve.  I absolutely hate it, and I hope I don't end up biting the dust like that, cuz these irresponsible make the beast with two backss aren't worth it.
OP's incident was at least an honest accident.  And on that note, perhaps a new helmet visor is in order, if he decides to continue riding, of course.  Don't know all the details of course, but visors make a big difference.
Dirty Duc
« Reply #13 on: August 21, 2012, 04:23:32 PM »
You might want to get a snazzy "hole cover" to hide the blemish, but it looks like yours is still intact.
1KDS
« Reply #14 on: August 21, 2012, 04:24:50 PM »
For sure, no offense OP, I was only commenting on that kid in the beemer.
Pages: [1] 2   Go Up
