S4 Mod (Updated Pictures)
Started by TitanMonsterS4R, August 25, 2012, 01:40:02 PM
muskrat
You listened.  [clap]. Painting the rizoma belt covers black looks excellent.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Uncle Mofo
Very nice, but I still think it needs a :L crankshaft cover ;)
                                   2007 red S4Rs
ccm900
Quote from: MonstaS2R on December 16, 2012, 06:17:39 AM
Thanks Zooom
Or hit it with some wd40 and a brown scotch brite pad like it says in the DIY section for way cheaper to restore the silver pipes!
TitanMonsterS4R
#123
Penske rear shock fitted.  Suspension setup completed by MRP Motorsports.  Sil Moto's off and being shortened then headed to to Figure Engineering to be powder coated either silver or black.
Now if He-Man can't do it, need to find someone who can take a stock headlight and drop a HID projector kit and hook up the ballasts.  Have all the stuff necessary just need someone to help with the work.  Also need a lens made as well... [beer]
TitanMonsterS4R
Quote from: ccm900 on December 18, 2012, 10:49:36 PM
@CCM900.  Thanks for the advice.  Got some pads and a new can of WD-40 and went to town.  Was able to get most of the midpipe cleaned and with the shortened cans, the rear is cleaned up nicely.
DucHead
#125
Re-route the fuel lines and starter wire.   ;D
Before:
After:
TitanMonsterS4R
Quote from: DucHead on December 30, 2012, 02:11:13 PM
Before:
After:
DucHead - did you need new/longer lines or just a reroute?
DucHead
Quote from: MonstaS2R on December 30, 2012, 03:26:38 PM
Hmmm...good question.   :P  It's been a while since I did it.  I do remember that I left the hoses attached to the throttle bodies intact.  I got the idea from Speedog.  If you want, I can take some pics under the tank tomorrow and post them up.
TitanMonsterS4R
Quote from: DucHead on December 30, 2012, 03:32:56 PM
greatly appreciated if you could.
DucHead
Quote from: MonstaS2R on December 30, 2012, 03:58:33 PM
Here ya go.  Better get a few feet of 5/16" FI fuel line just in case.   :)
Right side.  I relocated the fuel pressure regulator from the aluminum brace that spans the throttle bodies.
Left side shots, pressure regulator, quick disconnects and fuel line routing:
TitanMonsterS4R
Thanks for the pics DucHead.
DucHead
#131
Quote from: MonstaS2R on December 31, 2012, 12:49:10 PM
No problem, it really cleans up the look.  Ducati does a terrible job with fitment/routing of their lines, hoses and loom.   >:(
BTW, regardless of whether you reroute the fuel lines, if you add quick disconnects fit them in opposite directions to avoid connecting the lines incorrectly.
TitanMonsterS4R
I've really got nothing sig. to add.  Ducabike slave cylinder sourced, new 39T rear sprocket and barnett red pressure plate en route from Monsterparts.com :)  Tank should be back from DP's by the end of the month  [popcorn]
TitanMonsterS4R
#133
Progress on the tank/cowl color scheme.  Thank you DP  [beer]
TitanMonsterS4R
