January 22, 2025, 01:52:28 AM
S4 Mod (Updated Pictures)
5
6
7
8
14
Topic: S4 Mod (Updated Pictures) (Read 45889 times)
TitanMonsterS4R
Re: S4 Build (Pics Finally)
Reply #75 on:
November 11, 2012, 03:59:12 PM »
Quote from: ducpainter on November 11, 2012, 03:52:18 PM
999 didn't have radials?
If not the wheels will work.
999 wheels will not work as they used 5 bolt rotors.
Not planning on using the 999 wheel, just the Showa forks with the TIN coating. Understand the rotors will not work, though I wish they did. Just curious as to whether my S4 wheel will work with 999 forks...
Reply #76 on:
November 12, 2012, 12:07:04 AM »
Pretty certain the offset is 5mm more onthe 999 forks
Reply #77 on:
November 12, 2012, 04:08:20 AM »
Quote from: Raux on November 12, 2012, 12:07:04 AM
Is the difference in the wheel or the forks?
I know the rotor offset is different.
Reply #78 on:
November 12, 2012, 06:27:21 AM »
Quote from: ducpainter on November 12, 2012, 04:08:20 AM
forks
Reply #79 on:
November 12, 2012, 06:37:20 AM »
interestingly enough. the new 796 rotors are 5 bolt 10mm offset not the normal 15mm offset that almost all other 5-bolts are.
so you could run the 999 wheel with monster forks and 10mm offset 5bolt rotors from the 796
TitanMonsterS4R
Re: S4 Build
Reply #80 on:
November 12, 2012, 08:21:20 AM »
Quote from: Speeddog on October 25, 2012, 03:06:41 PM
You could fit some 749/999 10-spokers, but it's not a bolt-on.
Rear axle is bigger (30mm IIRC) and front wheel has 5-bolt disc mounting.
If you're correct Speeddog, what would it take to get a 749/999 rear mounted? I have a 999 front end (wheel, fork and rotors) from my S2R that I could part over with the Speedymoto triple. Just curious as to how much work would be needed to get that 749/999 rear tire to work.
Reply #81 on:
November 12, 2012, 08:51:01 AM »
848, new monster, hym wheels would be easier
even the 5-bolt
TitanMonsterS4R
Reply #82 on:
November 12, 2012, 09:07:32 AM »
Quote from: Raux on November 12, 2012, 08:51:01 AM
even the 5-bolt
How so? The 848/Hyper has the SSS while the S4 is DSS, right?
Reply #83 on:
November 12, 2012, 09:09:21 AM »
the s2r is the same as the all non-large axle SSS.
Anchorism just swapped 796 wheels with an S4R
Reply #84 on:
November 12, 2012, 09:09:52 AM »
woah... i pulled a stupid..
sorry S4, not S4R
Reply #85 on:
November 12, 2012, 09:10:56 AM »
look at ST4/SS wheels
Reply #86 on:
November 12, 2012, 01:31:27 PM »
Quote from: Raux on November 12, 2012, 09:10:56 AM
He's already got 5-spokers, same units as ST4.
Quote from: MonstaS2R on November 12, 2012, 08:21:20 AM
As far as the rear wheel goes....
**9 rear axle is 30mm, so a spacer could take care of the wheel itself.
You would need to have the **9 rotor, as it's a 5-bolt.
But it's a 240mm rotor, and it's mounted a good bit further outboard, so then you need the **9 caliper bracket.
Caliper may not clear the swingarm due to the configuration.
Perhaps it's all for naught anyway, as the wheel may be too wide... I don't have a **9 in the house to measure.
lazylightnin717
Reply #87 on:
November 12, 2012, 06:45:09 PM »
Doesn't the S4 speedo read off the rear rotor bolts?
Comes a time
Says don't you see
Gotta' make it somehow
Reply #88 on:
November 12, 2012, 06:51:22 PM »
Quote from: lazyjinglin717 on November 12, 2012, 06:45:09 PM
'02 S4, yes.
So there'd be the need for a speedo healer too.
'01 S4 is cable drive speedo off of the front wheel.
TitanMonsterS4R
Reply #89 on:
November 12, 2012, 08:01:37 PM »
Seems like far too much reworking and tweaking to get to fit. Might just save and bite bullet and get red PVR wheels or keep stock 5 spoke
5
6
7
8
14
