Fork oil & seals...... possible springs...?
Started by dan_t, August 26, 2012, 12:23:37 AM
dan_t
Hi all,
I've been a little quite around here for a while & thought I'd throw this one in to the ring to change all that.
I've recently noticed a little dark oily substance on the surface of the S4rs's lower oil cooler & just thought that I must have run over something on the road and that it's just flicked up. Problem is that I noticed it again though after washing it.
I went to wash the bike this afternoon and had a very close look at the front forks. I actually saw a droplet of what appears to my untrained eye to be oil on the very bottom of the fork itself. From what I'm guessing, my front fork seals aren't doing their job & very slowly, the oil is leaking out & causing the aforementioned dirty marks.
Here's the questions to you all;
a) what's involved in replacing the seals?
b) how much would this 'normally' set me back from a dealer?
c) if (when) I were to have this done, would it make more sense to also have the springs changed to better suit my weight?
The bike's an '08, has approximately 15,000 klm's on the clock and hasn't been ridden at all for pretty much 2 months (I've been away on an overseas trip).
Just after I purchased the bike a couple of years ago, I did take it to James at Zeno Damper for him to set it up for me, only using the stock Ohlin's parts. It did make a huge difference, but he did suggest putting heavier springs in there. His best guess was around the $1,000 mark all up.
Any thoughts, or even suggestions on where to go for this?
Cheers,
Dan
'08 S4rs;
Termis, DP C/F Short Tail, DP C/F Rear Hugger, Custom hand-made seat, Matris Steering damper, Pazzo Shorty Levers, Rizoma Dynamic mirrors, EVR Ventilated Pressure Plate, EVR Open Clutch Cover, SpeedyMoto Stainless Springs Kit, EVR Clutch Slave Cylinder, EVR Front Sprocket Cover, Evotech Performance Radiator & Oil Cooler Guards, Rizoma CT027R, CT017R & CT015R red fluid reservoirs, Powder Coated Rear Passenger Pegs, Oberon Racing Pegs, C/F Fairing stays, Oggy Knobs, ZG tinted Screen
Jukie
Hey Dan
I just had my forks changed when I was getting the repairs done to jukie. All I got done was to have the folks changed, oil change and seals and cost me $270
Before Honda CB125N
          Suzuki GS125
Now.   Ducati 620ie
          Lambretta Li150
          Ducati S4RT
brimo
Old dirt rider's trick, try cleaning under the seal first, you'll have to take the dust seal off first, run a piece of very thin plastic around under the seal. You can even use p800 emery paper as it has the stiffness. It's often not the seal that's stuffed but a bit of grit caught under the lip. Give it a shot, nothing to lose ay?
There's also a couple of you beaut tools on the market that do a similar thing. e.g.
http://sealmate.net/
From a story by RAT900
J5
go back and see zeno
he will do the minimum or the maximum depending on what you ask him to do
forget the dealer
its something that you are really better of seeing someone who does suspension and knows what they are doing
Rowdy
The guys at Speedys in Brisbane have done the suspension on both of my Duc's, Showa S4R and Ohlins 1098s. They did an awesome job with new springs, valves, seals and oil for $600.00 each bike, each end (front - rear). If you are getting the seals done, that is a great time to get the springs done too.
PS I reakon the Showa set up feels as good as the Ohlins (I'm no expert by the way but I did notice a big difference once the suspension was setup properly with the right internals).
You greatly underestimate the amount of overconfidence I have.
dan_t
Quote from: brimo on August 26, 2012, 02:00:01 AM
Great suggestion!
I remember reading about that somewhere else too. I think I'll give that a crack & see how we go.
Thanks everyone else for the input, really appreciated.
'08 S4rs;
