January 15, 2025, 04:41:47 AM *
News: Please Help
Pages: [1] 2   Go Down
Author Topic: Speedymoto top triple  (Read 2649 times)
duke8
« on: August 28, 2012, 03:47:37 PM »
Hi all
Just switched out my top triple and installed clip ons etc, and found that my forks don't sit all the way in the top triple. As you can see in the photo, they're about 3 1/4 of the way up.
I'm guessing this is because the speedymoto triple is flat, where the oem triple has the steering nut hole a little higher than the fork holes.
I'm unsure wether it is safe like this? It doesnt look like it....Can anyone offer some advice as to a good method of getting my forks to sit flush with the top triple? Is it as simple as just loosening the pinch bolts on the lower triple and sliding them up?
Any advice would be appreciated.... Cheers
'06 S4RS
supertjeduc
« Reply #1 on: August 28, 2012, 05:05:47 PM »
Yes
dufukincati
« Reply #2 on: August 28, 2012, 05:30:31 PM »
e-mail speedymoto your question?
13339 NE Airport Way #400 Portland Oregon USA 97230
orders@speedymoto.com
+1 866.375.0727 Toll-free
Dirty Duc
I'd rather be an anti-
« Reply #3 on: August 28, 2012, 08:49:49 PM »
Yes
Edited for clarity, and to get my post count up so I can post in the classified section... oh wait, that's a different board. Grin
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #4 on: August 29, 2012, 02:49:45 AM »
hmmm.... something aint right but i can't work out what  Undecided
does your steering lock bolt engage with the machined cut-out in the speedy triple correctly?
are you the first owner of this bike?  could a previous owner have dropped the forks in the triples 10mm or so??
« Last Edit: August 30, 2012, 02:57:12 AM by ungeheuer » Logged
duke8
« Reply #5 on: August 29, 2012, 03:27:53 AM »
Second owner but I doubt the po would have lowered the forks. Bike was stock standard when I got it, and by the looks of the oem triple, it seems it is at factory height... I was just curious wether others had the same issue and how they dealt with it...
The steering nut seems to be engaged with the triple ok...
'06 S4RS
« Reply #6 on: August 29, 2012, 03:33:33 AM »
I think it's just that the Speedymoto triple is thicker where the tubes slide in.
If you raise the tubes to sit flush the bike will turn in quicker...just be aware.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #7 on: August 30, 2012, 02:34:26 AM »
speedymoto triple isnt thicker, but it is flat  ____________
                                                            __
whereas stock triple is drop-shouldered  ___/   \___
but on my 696 and 1100 all this meant is that the Speedy triple clamps the stanchion tubes higher than deos the stock triple.... but theres still some fork tube above the top surface of the speedy triple (just not as much above as with the stock triple)...
something here isnt right and I'm buggered if I can figure out what it is  Undecided
« Reply #8 on: August 30, 2012, 02:44:19 AM »
He is the second owner
DarkStaR
« Reply #9 on: August 30, 2012, 12:45:25 PM »
All normal.  It is because the speedymoto triple is flat, and the stock piece is not as mentioned above.
Your going to have to silde the fork tubes up into the top triple clamp.  Handling will be affected.  How you deal with the is up to you.
Many ways to go about fixing it, and info should be availabe with a little bit of search-fu here.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #10 on: August 30, 2012, 07:24:15 PM »
All normal.
hmmm so speedymoto top triple is only a fit for S4R if you're prepared to alter turn-in....
DarkStaR
« Reply #11 on: August 30, 2012, 10:59:52 PM »
hmm...  Roll Eyes
You can add cycle cat to that list also.
It all depends on how the bike is set up.  If the forks are already passing up through the triple clamp like some do (e.g. 620), you might not have to do anything, and they'll end up flush.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #12 on: August 30, 2012, 11:16:33 PM »
hmm...  Roll Eyes
..which is what I said already... re: M696/M1100  waytogo
so fact remains.... that for a fit which doesnt look half-arsed on S4R... you'd need to raise the stanchion tubes in the triples thus quickening turn-in.
« Last Edit: August 30, 2012, 11:21:19 PM by ungeheuer » Logged
« Reply #13 on: August 31, 2012, 12:19:02 AM »
I can't believe every single person that's EVER bought a flat top triple had this issue and didn't bring it up before.
« Reply #14 on: August 31, 2012, 02:54:14 AM »
You're assuming the bike in question was as delivered from the factory.
Pages: [1] 2   Go Up
