February 23, 2025, 06:21:58 PM *
Author Topic: S2R Seat Cowl measurements  (Read 2148 times)
wasabi
« on: August 30, 2012, 06:20:23 AM »
I have a seat cowl that I am going to cover with Vinyl wrap. I am at work and it is at home.
Does anyone have the length and width of the seat cowl so I know how large a piece of vinyl I need?
Thanks
'07 695 Monster
"The life of a repo man is always intense"
S2R 800 '07
« Reply #1 on: August 30, 2012, 09:51:41 AM »
Total width all the way down under the wings 63cm (~25")
Total length including all the way forward to the wing tips 40cm (16")
Plus an inch or two extrab and another sheat when/if you scew it up...
Also, if you can - get the type that can be put on with soapy water for a super-easy bubble free application waytogo
wasabi
« Reply #2 on: August 30, 2012, 09:53:45 AM »
Excellent. Much appreciated.
'07 695 Monster
S2R 800 '07
« Reply #3 on: August 30, 2012, 09:59:13 AM »
You're welcome!
May I add: I think it will be very hard/impossible to get the vinyl nicely around all those edges and corners AND it won't stick on the rough inner surface. So, without having tried it myself, I suggest getting a fresh scalpel and carefully trimming it just at the edges.
wasabi
« Reply #4 on: September 10, 2012, 07:01:22 AM »
I finished covering the seat cowl. originally I thought I would have to get 4 pieces/colors of vinyl and fit them together to get the look I wanted, but instead they printed the design I wanted on 1 sheet. It was my first time using the vinyl and it took about 4 - 45 minutes sessions to finish covering the piece. I took breaks in between so I did not rush or get too excited and make a mistake. I have two pictures of when I was halfway finished and two when I was done.
'07 695 Monster
S2R 800 '07
« Reply #5 on: September 10, 2012, 10:33:34 AM »
Very cool design waytogo
What did you do around the edges?
wasabi
« Reply #6 on: September 10, 2012, 11:05:43 AM »
I just wrapped it under. I left a full inch of material to wrap it under and it seems to stick just fine. I did make a few cuts to make it stick flat underneath around corners. I am very happy with the result and absolutely beats the cost of painting with four colors. I bought the vinyl/graphic from http://www.pilotgraphix.com . I provided a picture and he designed and printed it. His shop is within the shop of http://autovinylsolutions.com/
Wasabi
'07 695 Monster
S2R 800 '07
« Reply #7 on: September 10, 2012, 11:08:17 AM »
Bookmarked  waytogo
madalf71
relaxing at home
« Reply #8 on: September 11, 2012, 10:45:56 PM »
Nice work!
