oo dark with replaced tank not starting
Started by richie ohno, June 28, 2008, 11:06:51 AM
richie ohno
i recently replaced my old tank on my '00 Dark with an '01 tank. The old tank had rusted and fouled up the fuel pump. I replaced both with functioning working parts. All lines are matched right, everything appears to be solid, but it won't start. Did i miss something or is there something else that could be causing this fata flaw? It tries to crank, but won't. I can hear the pump priming, but it sounds more like a vaccuum than the old pump did. Please help, bike is not happy with me for letting the tank rust.
did you say that?
Quote from: richie ohno on June 28, 2008, 11:06:51 AM
When you say it won't crank do you mean it won't turn over, or it won't start?
richie ohno
Quote from: ducpainter on June 28, 2008, 04:06:54 PM
sorry about that, it wont start
did you say that?
Quote from: richie ohno on June 28, 2008, 06:00:26 PM
I'd try switching the feed and return lines.
Assuming you bought a good used pump there really isn't much else that it could be.
If your lines still have the lettered bands the one with M is the feed.
richie ohno
Quote from: ducpainter on June 28, 2008, 06:21:35 PM
evrything was clearly marked and labled on both line and tank.  could it be the plugs?
did you say that?
Quote from: richie ohno on June 28, 2008, 06:30:19 PM
It's possible.
It's also possible you might have knocked something loose under the tank during the switch.
