Rear hugger bolts M695
Started by OrangeDragon, September 02, 2012, 12:33:13 PM
OrangeDragon
Thanks in advance for any help.
I am experiencing something very weird. I can't remove my rear hugger bolts. I keep lossening but they won't rise out of position.   It is happening on the two at the rear of the swing arm and the front right one.
I have removed the hugger before with no problem but today I am completely dumbfounded on what is going on?  Is there a threaded sleeve in the swing arm that is now just spinning?
Has any one experienced this before?  Any advice, help, solution?
2007 Monster 695 (153,000+ miles)
BK_856er
The small bolts that go into the swingarm use what are called rivnuts.  If the bolt gets overtightened or seizes up a bit due to corrosion/time/etc. the rivnut can spin and then you're kinda hosed.  Not sure there is a simple solution.  You may need to grind off the bolt head to get your hugger off.  Then you need to somehow contend with the spinning rivnuts.  I had this problem with one of the bolts to the upper chain rubbing block.
BK
OrangeDragon
Thanks for the explanation.  Hopefully I can figure something out.  Taking off the hugger makes for easy access for maintenance and cleaning.
