ST2R - mild concept
Started by Raux, September 02, 2012, 12:47:01 PM
pitbull
tuga27
Finally have nonfango rear topbox mounts....now to find a topbox that fits and get it painted
Ok clutch, brakes, and all little details set. Going to exhaust shop in the morning. Shouldnhave completed bike tomorrow to tkae photos
Ok exhaust is done, but not as perfect as I wanted. But stock exhaust fits as well. The mts exhaust sits too far back but had to be to give ground clearance. Bike rides nice. Speedo not working?
Quote from: Raux on May 25, 2015, 12:15:57 PM
That's so well done it looks OEM.
C'mon Ducati, build a stroked 1100 Evo to 1200 for a long legged gait as a sports tourer. Give it a big air box with ram air for 110 hp and 85 Ft/lbs.
Quote from: Raux on May 22, 2015, 06:26:42 PM
Speedo not working?
Check the cable and also check to see if the tabbed ring in the wheel was installed after the wheel powdercoating.
Thanks. It works slow like its geared wrong or slipping. I switched from kmh to mph speedo, could that be issue?
Ok thinking I have a 916 speedo and it has different gearing for speedo drive than st2.
Quote from: Raux on May 26, 2015, 07:13:15 PM
If that's the case a drive from the SBK should work. I wasn't aware they used different ratios.
MotoPsycho
x amount of ground speed is just that, but I could see the scale of it being different presentation wise. I've never seen a KPH speedo up close to compare. Assuming sweep is the same, I'd think it would just be a matter fitting the numbers in the right places. At the same time though, I could see a little gear in there somewhere being a shade different, enough to throw it off.
