ST2R - mild concept
Started by Raux, September 02, 2012, 12:47:01 PM
crappy PS work, but just thinking on paper
Kopfjäger
Well at least you could have used an ST2 pic.  :D
Hey Raux
I challenge you to leave it stock [laugh].
Ok, the only mods allowed are for practical, comfortable sports touring. ;D
yeah, yeah
trying to find an ST3 seat now. I also saw risers but not sure how they fit with the bars almost hitting the fairings on full lock now.
and trying to find the rear rack/bag that is compatible with the Nonfango side bags.
and need the straight kickstand and upgraded shifter (less close in to the motor)
and of course a better windscreen
ok so these are all standard 'fixes' and not mods
BUT that S2R swingarm just looks bad-ass on the bike. really updates the bike. that with maybe a MTS 1200 style exhaust
oh and upgraded forks with radial brakes
maybe 330 rotors
then the chip is need with a K&N filter...
oh I could go on and on and on
plus if i move back to the states I'll need a complete frame swap to a US VIN so might as well right? perfect time to do the swingarm
Scoober1103
I reckon the later Y spoke wheels would look great as well, a little less VFR! If your gonna go the whole hog and do the front end you could tie in the matching front wheel!
09 M1100 + stuff.
07 GSXR750 stock as a......
15 KTM Freeride 250r for hurting myself!
Quote from: koko64 on April 02, 2014, 02:52:23 AM
Don't buy cheap shit, it can cut your balls off.
zooom
Quote from: Raux on September 03, 2012, 01:39:48 AM
HeliBars would be the way to go!...I have heard some using convertibars, but not with much success...
as far as compatibility with Nonfango, not much at all out there, as I run into the same thing with the Nonfango's on my Gran Canyon....currently I am looking for a new closing mechanism for my Nonfango topbox that I got for my Gran Canyon from a guy that took it off his Cagiva Navigator, but the key snapped off in the lock cylinder and I jacked the mechanism up opening it up after the fact...so you either have to pony up and get Givi or some other company as a whole system.
so when are you going to put in the Ducati Designs headlight kit from Paul Gellar under that mode of thinking then?
2010 KTM 990 SM-T
Seriously, I reckon, ECU tune, open airbox, dialed cams (Brad might have specs?), maybe pull out the base gaskets or hicomp pistons and 999/1100 brake master cylinder and braided lines.
More power for hi speed touring and improved brakes.
oh for sure braided lines. these are mush
d3vi@nt
...then the chip is need with a K&N filter...
I picked up a new chip from a dude in Slovakia on e-bay for about $45 shipped.  They're either knock-offs, or he found a warehouse full of them somewhere. Either way, it made a huge difference on my '99 ST2. Runs better, stronger, no more stumbles at low RPM's and the fan kicks in a little sooner. Best upgrade I've ever made and inexpensive, too.
This is the dude: http://www.ebay.co.uk/itm/Ducati-ST2-Eprom-Chip-for-Open-Exhaust-965056AAA-for-Complete-Exhaust-assembly-/160879492770?pt=UK_Motorcycle_Parts&hash=item25752a3ea2
'13 MTS GT
'99 ST2
'07 M695 - Sold
thanks.
looks like a great deal. and yes, i get that nasty sputtering in the 3k rpm range
a bit more complete on the concept
Well wife signed off on the first part...
swingarm could be on the way soon  [Dolph]
minor adjustments coming
going to go with 916 era 3 spoker on the rear
will try to keep the ST2 stock can look but only on the left side if it fits with the swing arm
not upgrading the front for now either.
I put a few "parts wanted' posts for the project. so if you think you have something to help with the project, check them out.
