January 08, 2025, 02:40:52 PM
BST 6" rear on a 2009 M1100?
Topic: BST 6" rear on a 2009 M1100? (Read 1948 times)
mickb
September 05, 2012, 11:23:41 PM »
Hi,
I may be able to get a set of these (originally from an 848). Can anyone confirm whether they're a straight fit, as the rear is 6" ?
cheers.
S2R 800 '07
Re: BST 6" rear on a 2009 M1100?
September 06, 2012, 12:03:59 AM »
You can check that by identifying where your current wheel is closest to the swingarm, chain and other hardware.
It needs a couple of mm clearance to non-moving parts, a little more for the wheel to move back and forth as you adjust the chain and a little more towards the chain.
Online
September 06, 2012, 02:44:59 AM »
Isn't an 848 SSS and the M1100 DSS?
September 06, 2012, 02:56:45 AM »
Quote from: ducpainter on September 06, 2012, 02:44:59 AM
I was pretty sure the 848 and M1100 use the same rear wheel.
Online
September 06, 2012, 03:16:14 AM »
Quote from: Raux on September 06, 2012, 02:56:45 AM
I'm not sure at all...
hence the '?'.
edit...
so I checked the parts manual.
It is indeed a SSS.
[wrong again dear]
Last Edit: September 06, 2012, 03:21:00 AM by ducpainter
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
September 06, 2012, 03:30:22 AM »
848 and M1100 rear wheels are indeed interchangeable.....
.... but that isnt confirmation that these 6" BSTs will fit.
Last Edit: September 06, 2012, 03:34:01 AM by ungeheuer
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
mickb
September 06, 2012, 03:51:04 AM »
If my M1100 is a DSS, it means I've lost a bit
Thanks guys, did manage to find someone else who has done this, so looks good to go. Just need to find some sheckles now
