Helmet Fit Question
Started by ArabicaMan, June 28, 2008, 04:42:51 PM
ArabicaMan
I've got a Shoei X-11 that I've been wearing the past couple of months, and it's a great helmet.  It moves a ton of air, resists fogging, and is light and comfy (though a bit noisy at speed).  My question, though, is this:  How do I know if the helmet is too tight on my ears?  Around town, I tend to not wear earplugs, so the fit of the helmet seems fine, but when I'm going to be out on the real road or commuting (I ride an S4RS), I wear a set of SureFire SP-3 earplugs (which I highly recommend by the way), and the helmet seems to press against my ears in such a way that the plugs keep unseating.  So I wonder:  Does this mean that the X-11 is just a bit too narrow for my head shape?  And if so, would a different helmet (like the Arai RX-7) be a better fit?  Thanks for your help.  Cheers.
2007 S4Rs, full DP/Termi exhaust, DP short rear guard, Bitubo steering damper, DP billet indicators (front & back), Rizoma "Reverse Retro" mirrors, Matrix Motosports carbon fiber fairing support, various shiny DP carbon bits, custom license plate mount
Let me suggest different ear plugs.  I've noticed that different brands/styles fit with the helmet differently.
One type I wore the helmet kept constant pressure on them (imaging how comfy that was [laugh])
I now wear a custom set from Big Ear and they're the bomb!
hypurone
I wear an earplug in my left ear (radar) and feel a bit of pressure from my X-11. Nothing bothersome for me tho.
You might try getting diff pads for the earhole. They have replaceable components inside the helmet and a diff size might do what you need...
ArabicaMan
Quote from: hypurone on July 02, 2008, 07:21:22 AM
That's a great suggestion.  Do you (or anyone) by chance know if it's the center pad or the cheek pad that regulates the specific fit on the ears?
CDawg
I think it is the center.  You should be able to check.  Remove one of the cheekpad and wear your helmet sans 1 cheek pad.  I believe the cheek pad ends right below the ear.  Also, for what' its worth, the RF-1000 is slightly more rounded in fit than the X-11.
http://www.shoei-helmets.com/store/product_info.php?cPath=36_31_79&products_id=95
Also, you can try the roll-up ear plugs that are like 50 cents a piece.  They work well for me.
+1 on the Big Ear.  I have their headphone version and it's pretty incredible.
hypurone
Quote from: ArabicaMan on July 02, 2008, 08:42:08 AM
Yeah, it should be the center pad that you would want to change... I would have to go and look at mine to refresh my memory tho.
