check engine light and won't turn over
Started by VisceralReaction, September 18, 2012, 08:34:57 AM
VisceralReaction
Need some insight if anyone might have it. Drive the ST to work this morning per usual.
got into town and hit a stop light and noticed the check engine light was on. Rev'd the bike
gently and light went off. as the RPM came back down it came on again. Drove to parking lot
that was a couple miles away and light stayed off. Got into parking lot and parked and light came
on again. Rev'd it again and it still stayed on. Turned the bike off and then tried to restart.
Nothing. Lights all light up and all but the check  engine light stays lit and the starter just clicks softly.
Kinda like a dead battery. I just replaced the battery last Friday. Any ideas? I'm clueless. [bang]
Sounds like a charging problem.
Raux recently went through an issue with his ST2.
VisceralReaction
Thanks DP, I'm going to pull the plastic at lunch and also see if I can get an error code.
hoping for loose ground on the ECU or something easy.
Quote from: VisceralReaction on September 18, 2012, 08:52:16 AM
Could just be a loose connection at the battery. [where's the praying smiley?]
VisceralReaction
well I checked the error code and it's 5.2 which I think it just low battery but I just put a new battery in the bike.
Any thoughts? Only the one error code.
your low batt can be caused by a charging issue. how many miles did you put on it between the new batt and now?
Quote from: VisceralReaction on September 18, 2012, 02:25:28 PM
Either it isn't charging, a loose connection at the battery or elsewhere, or a defective battery.
If you jump it and it runs after disconnecting the jumper cables, it's most likely charging...that would leave one of the other possibilities.
Don't run the vehicle jumping...just use it's battery.
VisceralReaction
Quote from: He Man on September 18, 2012, 02:48:01 PM
Let's see Battery went on it thursday night so that would be 120 miles to work this morning before it died.
The old weak battery didn't make the eobd light come on even when it wouldn't turn over.
VisceralReaction
Quote from: ducpainter on September 18, 2012, 02:51:01 PM
Well I took the plastic off and checked over it and there isn't any obvious loose connections. I didn't trace back the main ground though.
Quote from: VisceralReaction on September 18, 2012, 03:07:12 PM
That's interesting
Quote from: VisceralReaction on September 18, 2012, 03:10:08 PM
When you say checked...did you actually put a wrench on things?
VisceralReaction
Quote from: ducpainter on September 18, 2012, 03:34:42 PM
That's interestingWhen you say checked...did you actually put a wrench on things?
No I'm at work and just did a "wiggle" test.
Going to jump it and test the charging system after work. then
charge it up and tomorrow do a load test and see where it goes from there.
Quote from: VisceralReaction on September 18, 2012, 03:42:09 PM
Plenty of info on the forum...
We're here to help. [thumbsup]
VisceralReaction
Alright, so I got the battery charged and put it on the bike last night and hooked the Multimeter up.
battery showed 13.4v, started the bike and it didn't go below about 10.8v.
Bike running at 2000rpm showed 12.65v, rev'd to 5000rpm showed 12.67v so it's not charging.
tested the positive lead of the RR and got .026v, then tested the neg lead and got .256v. According to that the neg lead
of the RR isn't grounded. I traced back the ground and all the wires are good and have clean connections.
Main ground is tight as well. So, based on this could the ground from the connectors to the RR be bad or within the RR itself?
I had similar issues like said before.
I actually did have chargning at one point it seemed.
RR was replaced
Battery sat about 2 weeks til i put the plastics back on
went for a ride (about a full tanks worth)
then noticed stuttering and RPMs drops on the ride
stopped for a rest
turned off bike
then nothing.. wouldn't start back up.
I got it push started (I pushed seanny101 dropped clutch) and was able to ALMOST get home. about 20km short.
definitely not charging.
had brand new battery, brand new RR... needs a stator.
now whether the RR went bad first (charge light on was how I noticed a problem) and then killed the stator
or the stator was always the problem I don't know
Good test procedure here...
If you suspect a bad ground try an external ground and see what happens.
