Source for longer Brake and Clutch cable
Started by nicholasv, September 19, 2012, 06:02:56 PM
nicholasv
Swapping in 848 forks on my S2R800 and added risers, etc.
My brake lines are just about long enough.
Is there a bike which would have longer lines stock which I could get from ebay?
I can order something from Speigler, etc, but just wanted to see if someone knew of a taller bike which would work here.
sofadriver
Try non-abs ST3 or post-2004 non-abs ST4s (they had adjustable bar height so they had longer brake/clutch lines)
you can ask the e-bay seller to measure them for you. you'll only need the measurement from the "tee" up. below that they should be the same. (I think  :-\)
Mike in Tacoma
'08 S2r 1000 - Red on Red
'96 900 SS/SP
IBA 38181
otter1
You can order them from ebay dealers that sell custom braided steel lines by the length. You need 10mm and need to indicate what orientation you want the end pieces at. Its easy to order and relatively cheap to buy these lines -- you can have a new set in your hands within a week.
