February 24, 2025, 02:06:14 AM *
News: Please Help
Pages: [1] 2   Go Down
Author Topic: Ohlins 46PRCS  (Read 7748 times)
« on: September 29, 2012, 09:30:03 AM »
I'm not familar with Ohlin shock models, it seems kind of cryptic.
There is a used 46PRCS i am trying to buy, but I'm not sure what the spec are on it. I keep getting mixed results.
Is it a DU333 or a DU046, both seem to show up on my findings for a 46PRCS.
I am finding the most common results are that the 46PRCS is a Gas type shock, not an emulsion shock. with double adjusters (rebound and compression) is it a good shock? I almost cant pass up on the deal if I can get it for my offering price.
« Reply #1 on: September 29, 2012, 09:40:28 AM »
http://www.ohlins.com/Our-products-new/Motorcycle/
That page will describe the code.
Yeah it's a good shock. Ohlins doesn't make junk.
« Reply #2 on: September 29, 2012, 10:05:35 AM »
So I can just ignore the DU333 or DU046 and go with that code chart?
P-Montotube high pressure gas type with external "piggy back" reservoir
R- Adjustable rebound with adjuster on the reservoir
Theres actually 2 R designations, based on location, does it make a difference? Or does R1 mean R and R2 mean RR?
C-Adjustable compression damping. Adjuster on reservoir
Theres also two designations, im assuming this is not high and low compression
S - Hose mounted hydraulic spring preload adjuster
I am trying to compare it the Penske 8983 Double clicker or 8987 triple clicker. I got my hands on one of their shocks and the build quality is absolutely amazing on it. Never actually held a ohlins unit in my hand, just ridden them.
« Reply #3 on: September 29, 2012, 10:12:45 AM »
You need to pay attention to the DU numbers. That will tell you what make and model the shock is valved and sprung for. It will also determine the length. Any make and model bike could use a 46prcs.
Not sure about the R1 and R2.
That shock does not have high and low speed adjustments. It does have remote preload adjustment.
« Reply #4 on: September 29, 2012, 11:13:01 AM »
I sent him a PM and waiting for his reply. i dont think he has the paperwork for it as far as teh DU number goes (unless its printed on the shock, which i dont think it is)
But it did come off an S2R800 which should be correct as far as shock length goes. I asked for the spring code  and ill get that later today. If the spring rate is near the rate i need i think the valve should be fine, but im not sure what the range of weights those valves are good for.
« Reply #5 on: September 29, 2012, 11:38:51 AM »
I don't think the number is on the shock.
I have a DU 440 on my bike and the shock came with a 9.5 and was replaced with a 10.0 and the valve works fine.
Chances are the spring wasn't replaced on the one you're looking at so the valve should be fine.
You'll like the Ohlins...they work great.
« Reply #6 on: September 29, 2012, 11:49:24 AM »
Here's the full rundown, DU 046-S46PR1C1S:
http://www.ohlins.com/Templates/Pages/TypeCode/TypeCode.aspx?typecode=S46PR1C1S
Problem is, that shock has a piggyback reservoir.
It will hit your swingarm.
That shock fits 'ST" framed DSS Monsters.
From Ohlins, you need a DU333-S46HR1C1S:
http://www.ohlins.com/Templates/Pages/TypeCode/TypeCode.aspx?typecode=S46HR1C1S
« Reply #7 on: September 29, 2012, 12:02:42 PM »
My current shock has a piggy back reservoir like this (999 Showa)
If its 100% certain to hit the swingarm, then i cant run it. I made a mistake reading it, it was off an M800, not an S2R800. Which pretty much means it wont fit eh?
« Reply #8 on: September 29, 2012, 12:05:39 PM »
I have a 848 shock with the horizontal reservoir.
Not sure if it would work with your bike.
BK_856er
2007 M695; 2004 749s
« Reply #9 on: September 29, 2012, 12:08:19 PM »
On my Ohlins (now on the way to a new owner) the DU code was ever-so-lightly stamped on the side of the bodycap in very small font.  Small amount of grunge would probably obscure it.
I think any rider would be happy with the fit/finish and performance of both Ohlins and Penske.  Penske is way more "billet" and produced in far smaller numbers, but both brands are absolutely top-shelf.
BK
« Reply #10 on: September 29, 2012, 12:16:23 PM »
Im looking at penske and ohlins only right now Raux, and that shock does not fit. its too short and the reservoir hits the swingarm for sure.
It would be nice to compare the DU046 to the 999 showa.  theres tons of room for the reservoir if the geometery of the shock is like the 999 one.
« Reply #11 on: September 29, 2012, 12:43:41 PM »
The DU046 isn't too short.
All of the ST-framed Monsters take the same length shock, even the S*R Monsters.
Here's a handy chart that shows configurations, model numbers, lengths, etc.
http://www.pashnit.com/product/ohlins/shocks_ducati.html
« Reply #12 on: September 29, 2012, 01:00:23 PM »
i was refering to the 848 shocks, they are 11inches long vs the 12 inch for the Monster.
thats a great chart, thanks speeddog.
the chart shows that the 999 and the ST frame shocks are both piggy back, im assuming they are using the same body cap so the geometery should be the same. So if it fits a 999, technically speaking, it should fit the S2R without interference with the swingarm.
I asked him for a section view of the shock so i can compare the angle of the shock to my 999 showa. if it matches up, the only real issue is the coil bracket that the 1000DS has. which i already cut off.
« Last Edit: September 29, 2012, 01:04:30 PM by He Man » Logged
MonsterHPD
« Reply #13 on: September 29, 2012, 01:31:34 PM »
I have an Öhlins that I bought new on my 2002 M900; the label on the box reads:
DU 046
Duc Monster S4 # 46PRCS.
This is what it look like on the bike:
The Shock for a 999 has the same overall length (350 mm C-C), but different stroke (999 has 76 mm, Monster 66 mm if memory serves).
This picture shows the 999 to the left, and the ST4S shock to the right. The ST4s shock will fit an M900 as they are the same length and same stroke. The difference in shock stroke is reflected by the diference in shock body length.
The 999 shock will fit the Monster / ST bikes as far as CC length goes, but the longer stroke will allow the rear wheel of a Monster / ST bike to travel too far, should you hit a really big bump. I also think the reservoir will interfere with the header from the rear cylinder; I haven´t actually tried it but from the looks of it I think they would interfere.
I would not bother about rider weight and shimming, since rider weight is mainly important for the low speed damping, easily compensated for by using the adjusters. The rest is a matter of personal taste, and if you are sensitive enough to want a change, you could talk to your suspension shop when you have your shock serviced. Which should be done every 2 or 3 years anyway.
Monster 900-2002 (sold, alive and well in the UK), 749R / 1100 HYM combo for track days, wifes / my Monster Dark 800-2003 (not entirely "Dark" anymore and a personal favourite) , 50% of 900SSie -2000 track bike for rainy days-now with tuned ST2 motor and Microtec ECU. Also parked due to having been T-boned on track.
« Reply #14 on: September 29, 2012, 01:39:32 PM »
couldn't you just change the stroke with a larger bumpstop
Pages: [1] 2   Go Up
