November 28, 2024, 10:06:33 AM *
Pages: [1] 2   Go Down
Author Topic: Accelerator problems  (Read 2806 times)
jamie2548
« on: October 08, 2012, 11:03:48 PM »
Hi all.
I have just got some bar risers for my wifes 620 and for the life of me I cannot(no matter how I route the cable) can stop it from pulling the accelerator when I turn the bars. bang head I cant move the cluster further down the bar because its located on a lug.
SO my question is. Can you get longer cables? Or is there any trick I am unaware of? Huh?
I tried to look at my new bike(Robs old one. Hi Rob waytogo) and I cant see anything since the sneaky bugger has hidden all the cables and wiring laughingdp applause
Any help will be greatly appreciated. Grin
dragonworld.
I can make like a tripod with my.....
« Reply #1 on: October 09, 2012, 01:19:20 AM »
It sounds like the cable is now too short and pulls when the bars are turned!  Roll Eyes
You can file the lug off without causing any problems, the cluster shouls still clamp up ok!  waytogo
But a longer cable might be the only solution!?  Undecided
svoloch
too old to remember my titanium member...
« Reply #2 on: October 09, 2012, 02:33:22 AM »
longer cable.
Тише едешь, дальше будешь
2009 Streetfighter S
exes:
2006 Sh1t Hot Black Xerox 999     1973 BMW R75/5
2001 BMW K1200RS                     1994 BMW R1100S
1974 Guzzi T3                              1975 BMW R90/6
1975 BMW R90/S                         1973 Suzuki T500
loony888
"I WAS GOING HOW FAST, OFFICER?"
« Reply #3 on: October 09, 2012, 02:46:44 AM »
if rob has hidden them he may have routed them differently, i'd be making sure they're routed as per the workshop manual then seeing how much slack you have at full lock. beats coughing up for new cables, there _should_ be enough there to make them work.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
svoloch
« Reply #4 on: October 09, 2012, 02:51:45 AM »
with bar risers, you can run out of length quickly.  I'm not as familiar with the monsters, but I helped a friend put cycle cat risers on his 999, and we definitely had to get a longer cable, there was nowhere near enough play to make it work.
exes:
Betty
« Reply #5 on: October 09, 2012, 01:34:41 PM »
Just to clarify ... he doesn't have a problem with the M1000 (Rob's re-routed bike). The problem is with the M620 and new risers.
An option may be to lower the front end but this will impact the handling (perhaps in a good way?) ... and if the bike has a stock linkage at the back you won't be able to compensate with similar changes on the rear. Adjustable links may still be available though.
loony888
« Reply #6 on: October 09, 2012, 01:51:44 PM »
ahh righto, didn't read it properly. usually the cable routes around the LHS of the headstock in a nice smooth arc, you may get away with changing that to the RHS with the cable routing more upwards but other than that there's not much to change, are longer cables available?? california cycleworks maybe??
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
svoloch
« Reply #7 on: October 09, 2012, 02:17:20 PM »
Just find one with the same diameter and a bit more length ( who hasn't had that problem?!? ).  I think we used one from a multi, don't recall exactly.
exes:
jamie2548
« Reply #8 on: October 09, 2012, 11:58:31 PM »
Thanks for all your advice waytogo I'm actually going to see if I can get a longer insert and make one up myslef. Seems like the obvious way to do it Grin.
Thanks again for your help chug
dragonworld.
« Reply #9 on: October 10, 2012, 12:14:09 AM »
you'll need the correct length outer as well, otherwise you might not be able to take up/adjust any excess freeplay!! waytogo
jamie2548
« Reply #10 on: October 10, 2012, 01:16:55 AM »
The outer fits fine  so all good there dragon  waytogo Ill see what i can find at the bike shop tommorrow http://www.firestormmotorcycles.com.au/universal-motorcycle-inner-throttle-cable/   << this is what Im thinking i will do
Betty
« Reply #11 on: October 10, 2012, 10:09:43 AM »
Umm ... is the 'fast idle' effected in the same way?
GK
« Reply #12 on: October 12, 2012, 12:19:30 PM »
Have you used all the adjustable/available slack in the cable? I know there's the actual cable length, but there's also a bit of freeplay adjustment.
If you have done this, then I guess you're up for another cable. I would prefer that than suspension fiddling, especially if the Mrs is happy with the current handling.
All the best with it.
GK
2001 Ducati  Monster 900S ie
Gone but not forgotten!
jamie2548
« Reply #13 on: October 12, 2012, 03:06:31 PM »
Thanks Guys. I acatually ended up getting a new cable insert and using a little more length. Worked a treat waytogo
I agree GK. The bike actually hasnt been set up for the missus yet but still mucking around with suspension just to get a cable to work it out of my league. Huh?
GK
« Reply #14 on: October 12, 2012, 10:12:06 PM »
Glad you got it sorted. waytogo
GK
Pages: [1] 2   Go Up
