Are 2007 monster 695 wheels interchangeable with 99 monster 750?
Started by Racka0, October 09, 2012, 02:50:57 PM
Racka0
I need to now if anyone  of this forum made them fit to an older carb monster. What should I modifiy to fit 2007 695 front and rear wheel in to a 99 monster 750?
PLZ help me out guys .
Thanks
BK_856er
The M695 three-spoke Brembo wheel details are as follows:
Front = 17x3.5", 25mm axle diameter
Rear = 17x4.5", 25mm axle diameter
Questions for those in the know:
- If the 750 axle diameters are different, is it enough to just replace the wheel bearings, or are there other dimensional considerations?
- Is the speedo pickup on the front wheel on the 750, and if so can the modern wheel be configured that way?
- Will the 750 forks accept a second brake caliper for a dual-caliper configuration, or are different forks required to accomplish this?
BK
BK_856er
One other thing to consider - the '99 probably has 40mm brake caliper bolt spacing on the forks vs. 65mm spacing on the '07.  Not a wheel consideration per se, but a related front brake one.
BK
brad black
the 99 will have a 17mm rear axle, possibly a 25mm front and 65mm front caliper mount bolt spacing.  99 is when the 900 went to the 25mm axle, not sure about the 750.
you can change the bearing and spacers for the different axle.
the front wheel probably has the machining for the speedo drive.
Brad The Bike Boy
http://www.bikeboy.org
