February 24, 2025, 11:58:22 PM *
Author Topic: Least expensive 696 adjustable brake lever  (Read 1559 times)
jrswanson1
« on: October 11, 2012, 07:43:03 AM »
When I dropped my Monster 696 in July, the brake lever got bent and the adjuster dial got dinged up, so now when I try to adjust it, the number two setting puts the brake lever about 1.25" away from the throttle.  Is there an inexpensive adjustable brake lever available that doesn't look cheesy and doesn't cost $200?  I'm changing the brake lever now so I can still ride it until I can snag something nicer next year.  Thanks.
freeclimbmtb
From Zero Member to
« Reply #1 on: October 11, 2012, 07:50:10 AM »
I swear by my ASVs.  $130 or so each.
2011 Monster 796 ABS
Dirty Duc
I'd rather be an anti-
« Reply #2 on: October 11, 2012, 08:00:25 AM »
fleabay has cheapo china knock-offs... the price varies a little, but they are for a set.  There are reviews around here somewhere.
Omnipotent Potentate
Personal Pretext
« Reply #3 on: October 11, 2012, 09:16:30 AM »
I got a china special from ebay seller panmarco1111. At the price point I figured WTF, if it sucks I'm not out much. Turned out to be actually quite nice. Not ASV or CRG quality, but the value couldn't be beat. And when it seamed the first one went missing they sent a second one free of charge. The first one showed up a couple days later, of course...
So the china stuff can be a good value - but you do need to be more wary.
If you want to be sure of things, ASV, CRG or Pazzo... but they won't be so low cost.
S2R 800 '07
« Reply #4 on: October 11, 2012, 09:34:47 AM »
http://www.monsterparts.com/pc/ADJLEVER/CB-Reservoir/ADJLEVER.html
JEFF_H
« Reply #5 on: October 11, 2012, 03:03:07 PM »
also check with the dealer for a replacement brake lever for a M-Hyper 796
adjustable and cheap(ish)
schmaltz03
« Reply #6 on: March 05, 2014, 03:33:51 PM »
got a Chinese knock of set on amazon for 25$ they work better than factory.
Dirty Duc
« Reply #7 on: March 06, 2014, 04:58:07 AM »
Also, CRG "Swap meet" http://crg-direct.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=SWAP
