December 21, 2024, 07:12:52 PM
Throttle..... check, Front Brake......ch....
Topic: Throttle..... check, Front Brake......ch.... (Read 3724 times)
BastrdHK
Quit complaining, and ride the damn thing!
October 11, 2012, 02:04:02 PM »
The front brake works
Man, I thought Capirossi's tumbler in GP and Biaggis at Phillip Island was nasty......this is the worst I have seen.
M-ROCin' it!!!
Omnipotent Potentate
Personal Pretext
Re: Throttle..... check, Front Brake......ch....
October 12, 2012, 05:52:33 AM »
Sweet jebus... he almost tagged the rider 2 slots up with the bike-missle.
IdZer0
BE
October 12, 2012, 10:11:50 AM »
I don't understand how that's even possible. How do you generate enough force to lock the front at that speed ?
replaced by 2011 848 EVO
October 13, 2012, 09:07:07 AM »
Quote from: IdZer0 on October 12, 2012, 10:11:50 AM
what he said! Ive never in my life thought you could generate enough force to flip the bike at speed. you can slip the front all day and high side or low slide, but thats a straight up endo!
BastrdHK
October 16, 2012, 07:55:36 PM »
I think its easily done.....on track. I have locked the front once on street tires and interstate/concrete. Luckily, I realized what happened and immediately released, plus I was straight up and down.
With the amount of grip race compounds generate, I think it is totally possible. We see it all the time in every Road Race series. Riders lift the rear off the ground under heavy braking. Maybe this, with his inability or to shift weight backwards caused his body weight to fly forward and compound the problem.
At the speed he went past, he clearly came in way to hot and panic braked.
Last Edit: October 16, 2012, 09:18:43 PM by BastrdHK
M-ROCin' it!!!
IdZer0
BE
October 17, 2012, 07:58:34 AM »
Yeah, but not at that speed. The tendency to lift the rear decreases a lot with speed.
The only reason I can think of is that he was sitting to much to the front.
BastrdHK
October 17, 2012, 09:19:56 AM »
Quote from: IdZer0 on October 17, 2012, 07:58:34 AM
I have never personally had any experience, nor do I really want to. I have definitely seen rear lift in GP and WSBK races at similar speeds however, so I disagree.
M-ROCin' it!!!
Triple J
October 19, 2012, 12:24:31 PM »
Maybe he bumped into someone and the contact pulled his brake lever?
BastrdHK
October 19, 2012, 12:28:03 PM »
True, we have no clue what was going on behind.
M-ROCin' it!!!
