Zard Owners?
Started by scduc, June 29, 2008, 06:56:58 PM
scduc
I know I have beaten this subject to death, but one more question please. In all of the photos I have seen, the pipes look like they have a "taper" to them.(Getting smaller towards the open end). I am getting close to a decision and just want to make sure they are right for me. Only other thing is getting a DP ECU without having to shell out for the termi kit.
Big T
They do have a very slight taper. Smaller at the exhaust entry tapering to bigger at the outlet.
And you can buy the DP ECU separate to the Termi kit. Mine was part number 96517906B.
I put on the Zards, DP ECU & DP Open Airbox, had it "tuned" by my Ducati dealer and it was a new fire breathing Monster....  [thumbsup]
   .... This is your captain speaking. Please fasten your seat-belts as we prepare for take off.... (I'm the passenger now....)
Wanwo
I assume by 'pipes' you're refering to the canisters, in which case Big T is correct - slight taper. Not something you really notice unless it's pointed out to you.
Apart from the ECU (I run a PCM3), only other issue is the lack of a heat guard. I prefer the clean look of no heat guard. Just applied a heat resistance mod to my boot.
JDS 07 S4Rs
Quote from: scduc on June 29, 2008, 06:56:58 PM
Opposite of what you said. Bigger at the end of the can(like "Big T" said) Which could present a slight problem if you ever considered shortening the Exhausr cans.
I havent seen any one with the PC3/Dynojet or Rabidbike post any significant Dyno #s like the ones posted by the guys with the DP ECU.
Rumor has it that Rapidbike now has a fix for our S4RS. Dam rumors  :)
2007 S4RS
2007 1098S Salvage Title (that's it. NO MORE BIKES)
02 GSXR 750 Trackbike - Ins Write/off
06 ZX636R Trackbike  - Ins Write-off (I couldnt help it, the price was right)
2003 BMW 1150R
2004 450 YZ
&,,, a few others :-)
Big T
#4
Quote from: Wanwo on June 30, 2008, 06:23:31 AM
Fixed the heel guard issue with some CF, a dremel, SS hose clamp and bracket from my local Duke dealer.....  [thumbsup]
uclabiker06
Quoteonly other issue is the lack of a heat guard. I prefer the clean look of no heat guard. Just applied a heat resistance mod to my boot.
+1.  Me too.  I think to many people ruin the look of the pipes by adding a heat guard;  not worth the effort IMHO.
2006 S2R
2009 Smart
