Foot Peg Holder Spacers - where do they go?
Started by Jordan1234, October 14, 2012, 08:45:10 PM
Jordan1234
Hello! I'm reassembling my 2002 M750 and I'm stuck on the foot peg holders. I cant tell from the exploded view which spacers went where, and its been a year since I took them off to rebuild the engine. I'm not even sure if I have all of the pieces any more. [bang]
Attached is a photo of all the spacers I think were involved.
  • The bolts in box 1 are definitely the upper right side ones, since there was one of them still stuck in the peg holder.
  • Box 2 is presumable the lower bolts for both sides, leaving box 3 for the upper bolts on the left side.
  • I'm pretty sure box 6 holds the muffler on the right side
  • Box 7 and 5 correspond to the upper bolts with the smaller diameter threads. Am I missing one of the thin washers? Its strange that I have 3. Which side do the thick spacers in box 5 go?
  • Box 4 (the number is obscured - its the upper right group) goes to the lower bolts, but am I missing one? In the exploded view the spacers on the lower bolts are different part numbers for the right and left sides... is one of these spacers for something completely different?
  • Can I assume that box 8 goes on the lower bolts on both sides?
I'd really appreciate any help - this is a frustrating place to get stuck... I'm so close to having it running again after a complete tear down and rebuild.
Thanks - Jordan
FrankenDuc
The right (throttle) side has four thick spacers. All four of mine are the same thickness, but I pulled a 1/8" piece of sheetmetal with some charcoal thingy attached to it from the top two of mine and threw it over my shoulder.
Lower left has two thinner aluminum spacers, and upper left pair are essentially washers.
larger thread diameter are the lowers on both sides, these go into the softer aluminum engine case.
smaller thread are the uppers, these go into the harder steel nuts welded to the frame.
There's also bushings to the stock exhaust hangers, one on each side (thicker on the right, thinner on the left), which I suspect you've got mixed in there.  The bolts for these are thinner even than the uppers that go into the steel bolts welded to the frame.
I do the same thing to myself all the time, I'd make sure the bolts are the right thread pitch and have adequate purchase depth (enough I'd be willing to stand on them), none of the cast metal has to bend, and that the rubber bushings on the footpeg brackets are just pinched, and otherwise not worry too much.
Hope this helps...
"hammer to fit, paint to match"
Jordan1234
Jordan1234
Ok I have another one:
My old rear brakes had these little metal plates, but I don't see any mention of them in the manual.
My new brake pads came with little pins, and I don't see any mention of those in my manual either. Also, the old brake pads didnt have any pins.
Here is what the plates and pins look like:
I think they go like this... I could see how the pins could go the other way, too. I can only guess that the arrows are supposed to point toward the front.
Does that seem right? Anybody seen these before?
Thanks!
-Jordan
Seen them back around...maybe 2003.  The purpose is to (hopefully) avoid brake squeal.  They didn't work for whatever reason I don't remember on the aftermarket pads I installed.  They don't even show up in the parts catalogue.
Jordan1234
Ok great - I'll ignore them.
What about the little pins? Can I also ignore those?
