October 31, 2024, 05:22:50 PM *
News: Please Help
Author Topic: Bad fuel pump survey  (Read 1467 times)
scaramanga
« on: October 20, 2012, 03:34:57 AM »
hello all
Just for shits and giggles I'd like to compile some data on the many fuel pump issues that i and others have had.
What i would like is for people to pm me with 3 pieces of info 1)make and year 2)type of fuel used[% ethanol] 3)resolution
I will take this info and put it in one neat post.
I'll start
2008 s2r1000 , PetroCanada 94 10% , re-soldered joint and replaced bad epoxy
« Last Edit: October 21, 2012, 02:52:05 AM by scaramanga » Logged
2008 s2r1000
2011 sf1098
jerryz
« Reply #1 on: October 20, 2012, 11:21:28 PM »
OK I will add my data
1991 750ss carby never had a fuel pump issue in 5 years running on regular 95RON petrol even with rusty tank inside now coated with Petseal.
2000 Monstercarby   never had a fuel pump issue in 8 years running on regular 95 RON petrol.
2001 Monster S4 EFI never had a fuel pump issue in 6 years of running on 10% gasohol 95 RON
but once a month filled with regular 95RON  petrol and always stored with regular petrol for long periods ...NEVER Gasohol.
militar3rd
Ce Sharp
« Reply #2 on: October 21, 2012, 10:11:34 PM »
I got me a
2001 Monster 900Si.e.   I always ran 93-95. No fuel pump problem, but I definitely clean the lines every time I take dents out of my tank, at leasst once a year.  bang head
2006 Kawasaki ZZR 600 (Track&Commute)
2001 Monster M900 Si.e. (Current)
1998 Honda Superhawk VTR 1000 (Sold)
1993 Honda CBR 600 F2 [101,000+ miles] (Sold)
1983 Kawasaki GPZ 550 [220,000+ km] @ Philippines (Donated to degenerate cousin)
iltl32
« Reply #3 on: October 22, 2012, 05:05:39 AM »
2005 Monster 620 Dark.  94 octane @ 10% eth.  Resolution: re-soldering the wires and re-applying epoxy.
2005 620 Dark
krista
... does she have a
ducati addict
« Reply #4 on: October 26, 2012, 02:30:57 PM »
A lot of people with the plastic-tank'd monsters are going to be having problems in the near future. IMHO, there's something wrong with how the wiring harness is laid out and wire strain is the cause of the problem. Or "they" (Bitron) cheaped out with their epoxy. Even if they did the epoxy wrong, that would lead to leaking, not wires breaking...
Scooter-Trash
« Reply #5 on: October 26, 2012, 02:40:28 PM »
My 1991 900ss' fuel pump crapped out after 3 years and 28K miles.
Probably not a data point you care about Wink
scaramanga
« Reply #6 on: October 27, 2012, 05:58:36 AM »
chris
I'm convinced the epoxy used is not chemically compatible with ethanol.Also tin/lead solder is definitely NOT compatible with ethanol. Therefore when ethanol leaches through the epoxy and reaches the solder joint(tin/lead) it eats at the joint.
So here we have enigine vibrations shaking wires that are being held by a corroded solder joints and epoxy that has being transformed into a sponge. Eventually the wire connection fails.
If it takes years for the ethanol to reach the solder joint (half way between the inside and outside of tank) then it would take the same amount of time before reaching the outside and leaking.I'm sure it wasn't their intention to cheap out on the epoxy but rather the epoxy wasn't designed to withstand the addition of ethanol to the petrol.
Materials NONCOMPATIBLE with fuel ethanol
Metallic: Zinc, brass, lead, and aluminium Ternary (lead-tin-alloy)-plated and steel lead-based solder.
Nonmetallic materials: Natural rubber, polyurethane, cork gasket material, leather, polyvinyl chloride (PVC), polyamides, methyl-methacrylate plastics, and certain thermo and thermoset plastics.
« Last Edit: October 27, 2012, 06:11:32 AM by scaramanga » Logged
2008 s2r1000
2011 sf1098
« Reply #7 on: October 27, 2012, 03:09:28 PM »
1992 Superlight.
Known the bike since 2000. Still on the same pump. I know three out of the four owners and they avoided Ethanol blends.
My '95 M900 is on the original pump which I have disassembled and cleaned once.
I avoid the 10% Ethanol blend being introduced down here.
