February 24, 2025, 05:06:05 PM *
Pages: [1] 2   Go Down
Author Topic: Minor dry clutch upgrades?  (Read 5748 times)
d3vi@nt
« on: October 21, 2012, 09:35:09 AM »
The clutch on my '98 ST2 is starting to groan (but not slip) on anything other than an easy launch. While have it open and apart, are there any minor upgrades that are worthwhile? Different material springs, Ti bolts, vented pressure plate, etc.?  I'm not interested in running an open clutch and not interested in bling -just cost-effective improvements.
Thanks!
'13 MTS GT
'99 ST2
'07 M695 - Sold
« Reply #1 on: October 21, 2012, 09:57:01 AM »
stock springs are lighter than ss or ti I've heard
i think the big thing is a better basket to reduce the clatter
« Reply #2 on: October 21, 2012, 10:15:35 AM »
How many miles on the bike?
Likely needs a new set of plates and a new basket.
Barnett has a nice basket.
d3vi@nt
« Reply #3 on: October 21, 2012, 11:49:24 AM »
It's only got 24K miles on the clock.  Guess I'll see what I've got when I crack it open.
Looks like about $200 for plates and $300 for a basket. Yikes.
'13 MTS GT
'99 ST2
'07 M695 - Sold
« Reply #4 on: October 21, 2012, 12:02:49 PM »
A good set of springs and plates will work. If your bike has a steel basket it could take steel plates. If you want to change to an alloy basket the NGR basket is a good price. I saw one in the parts for sale section for $160.
Firstly see how beat up it is in there.
Sometimes giving all the plates a good clean will stop the clutch groaning. I have had good results with Barnett springs assisting clutch engagement. A  flush of clutch fluid is a good practice every couple of years.
« Reply #5 on: October 21, 2012, 03:29:01 PM »
There's a washer under the hub retaining nut (has 6 cut-outs for the bolt towers in its OD).  If that washer is loose to the touch, you could need a new hub.  I've made shims out of large thin washers in the past as well as double stacked OE washers to help...
Best bang for the buck can sometimes be had in an entire used clutch from a later model bike.  Lots of slipper clutches get installed and the OE's go on ebay...
moto
« Reply #6 on: October 21, 2012, 10:29:21 PM »
One of the nicest aluminum baskets is made by NGR.
New it is only $179
NGR Clutch Basket
These guys supply Bimota and others.
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
d3vi@nt
« Reply #7 on: October 22, 2012, 06:22:37 PM »
Cool. Thanks for all the feedback.
Any thoughts/experience with the Spyder ring retainers (http://www.desmotimes.com/product10.htm) versus the individual spring caps?
'13 MTS GT
'99 ST2
'07 M695 - Sold
Omnipotent Potentate
Personal Pretext
« Reply #8 on: October 23, 2012, 05:40:25 AM »
AFAIK that bit isn't worth the cash. Supposedly it evens out the spring force... but I think it's more snake oil than real issue. Also, it'll be heavier and prevent the use of some pressure plates like the ones from SpeedyMoto that cover the full height of the spring.
rozer
« Reply #9 on: October 23, 2012, 11:30:44 AM »
If your clutch plates and basket all need replacing why not opt for a EVR 48 Tooth Clutch Plate and Basket Kit?
I've been told these kits are more durable and make less noise than OEM parts.
http://www.bellissimoto.com/EVRClutchParts.html
d3vi@nt
« Reply #10 on: October 23, 2012, 06:45:49 PM »
An interesting thought, but at $1600, it's almost half what I paid for the bike.  My Monster has a slipper and as I switch back and forth between the two bikes, I'm still undecided as to which I prefer -I'm leaning towards the non-slipper.
I have yet to tear into it, so we'll see what needs to be done soon...
'13 MTS GT
'99 ST2
'07 M695 - Sold
rozer
« Reply #11 on: October 23, 2012, 08:30:19 PM »
I meant the non-slipper option also available at BelissiMoto. Wink
The kit is priced at a much more reasonable $474.95.
d3vi@nt
« Reply #12 on: October 24, 2012, 05:43:24 PM »
Ah. Thanks for pointing that out. I saw the price tag for the first item and missed everything else. That does seem likea good deal.
'13 MTS GT
'99 ST2
'07 M695 - Sold
d3vi@nt
« Reply #13 on: February 24, 2013, 09:25:15 PM »
Now that it's starting to warm up in my garage, I'm about ready to tackle this. I figure I'll clean things up first and see how it goes. Are there any special tools needed for this operation?
'13 MTS GT
'99 ST2
'07 M695 - Sold
brad black
« Reply #14 on: February 25, 2013, 05:16:09 AM »
the lithium grease mod apparantly works well.  if the clutch isn't slipping there's no point replacing anything so just make it work nice.
Brad The Bike Boy
http://www.bikeboy.org
Pages: [1] 2   Go Up
