October 31, 2024, 03:53:02 PM *
Author Topic: hydraulic Banjo Brake Light Pressure Switch  (Read 1009 times)
TitanMonsterS4R
« on: October 22, 2012, 05:50:11 AM »
Need to install a banjo brake switch to work with the new Ducabike rearsets I purchased.  Never done it before, how easy is the job? Installation
« Last Edit: October 22, 2012, 07:02:24 AM by MonstaS2R » Logged
Omnipotent Potentate
Personal Pretext
« Reply #1 on: October 22, 2012, 06:52:06 AM »
EASY!
Just get a two wire AMP Superseal connector to terminate the wires and it hooks right in. Obviously you're in for a brake bleeding session as part of it, but it's no harder than that.
TitanMonsterS4R
« Reply #2 on: October 22, 2012, 03:06:04 PM »
EASY!
Stupid question, but why must i bleed the rear brake after installing rearsets?
mmakay
695
« Reply #3 on: October 22, 2012, 04:29:42 PM »
...can't replace the banjo bolt with a pressure switch without bleeding the brakes afterwards.
- Mickey
Personal Pretext
« Reply #4 on: October 23, 2012, 04:07:33 AM »
^^^ That
You're removing the stock banjo and replacing it. Going to be a lot of air in the lines if you don't. So much the brake probably won't function at all, even to the point of not lighting up the brake light as you can't make sufficient pressure in the system
TitanMonsterS4R
« Reply #5 on: October 23, 2012, 06:09:18 AM »
^^^ That
Thanks.
And knowing is half the battle....G.I. Joe's
