How to Synchronize Throttle Bodies.
Started by militar3rd, October 28, 2012, 08:03:25 PM
militar3rd
Sup guys. The 7K mile interval service came up and I wanted to do EVERYTHING. Valves were at spec, timing belts were replaces, air filter cleaned, and so on... However, I'm having trouble on how to synch the throttle bodies. I just removed the ugly Evaporative Emission Canister out of the way, and I know that's where you plug in the tubing for the vacuum gauges. But, wheres the Idle Screw, my buddy said that on his ST2, its inside the ECU?!?!?!
There isn't any posts out here saying how to synchronize the throttle bodies of a fuel injected monster.
I've heard about a guy in a local meet saying that he sync'd his cbr f2 using a homebrew system that utilizes 3/8" pvc clear tubing as a vacuum gauge. Is this applicable to the monster?  ???
Btw, I have an 01 M900 Si.e.
2006 Kawasaki ZZR 600 (Track&Commute)
2001 Monster M900 Si.e. (Current)
1998 Honda Superhawk VTR 1000 (Sold)
1993 Honda CBR 600 F2 [101,000+ miles] (Sold)
1983 Kawasaki GPZ 550 [220,000+ km] @ Philippines (Donated to degenerate cousin)
Ddan
The synch screw is in between the throttle bodies and is a pregnant dog to get to, especially once the exhaust gets hot.
There are lots of tutorials on-line to make a manometer
Ducati Monster Forum at
www.ducatimonsterforum.org
booger
Screw both bleed screws all the way in, connect the gauges to the nipples, run the bike @3k rpm, balance the gauges by turning the sync screw located between the TBs. Set idle speed by turning both bleed screws back out equally until correct idle is achieved.
With my bike the sync screw head was facing rearward. This made for a very awkward adjustment. Hopefully on yours, the screw is facing the front. This should make the adjustment part a lot easier.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
brad black
this report has the sync stuff and idle mixture starting down the page.
http://www.bikeboy.org/ducati2vthrottleb.html
Brad The Bike Boy
militar3rd
Just did it, fairly easy. And runs like new now.  [thumbsup]
Thanks
iltl32
You can mess with the idle/throttle bodies without adjusting the TPS?
2005 620 Dark
Quote from: iltl32 on October 30, 2012, 05:13:18 PM
As long as you don't adjust the throttle stop...
yes
