ST2-ST4 dog-bone same as 749/999 ?
Started by phantomaz, November 01, 2012, 10:37:35 AM
phantomaz
Hello guys ,are those two linkages same ,or there are some differences? On the pictures they look the same ,but the serial number is different 73210031 vs. 73210034 or ..32 . I am planning to do the 749/999 swingarm swap , I have all the parts except the dogbone. Anyone ?
it will fit? the 999 cases are narrow cases (with bearing in swingarm), the st2/4 wide cases (with bearings inside)???
phantomaz
It won't be direct swap ,a lot of modifications will be required , but my question is about the dogbone/shock linkage/ st2 vs 749, are they the same?
sorry. all i know is the st2 and s2r are the same.
phantomaz
yes ,they have the same serial numbers. thanks!
krista
I just looked at S2R1000 and 749 that are here. The Monster dog-bone looks longer. It is also starting at a different angle... it points down at the front 30+ degrees. The 749 one is pretty much flat with the ground.
phantomaz
Thank you very much chris, that's what I needed. On the pictures they looked the same ,and I wondered where the difference is, this one helped a lot , because I was almost ready to buy the st2 linkage. Best regards!
MonsterHPD
#7
As it happens, I've been looking into this in some detail over the years, and a bit more focussed lately since I need to design a linear linkage for the tracSTer track-day bike.
I do not have all the facts (of course ...) but below are a few facts for the different links I've checked. The different bikes have different wheel travels, shock travels and leverage ratios; all rockers have a "positive gullwing" shape except for the 749R / 999R "linear" rocker, which is "negative gullwing"
As it turned out, I'll have to design a custom rocker for the tracSTer, but that's another story.
The dimensions below are as accurate as I could make them without access to a proper measurement machine, whatever they're called, but should be generally accurate enough to see the differences. I hope the table comes out reasonably readable, the forum would not copy an excel table properly.
Model   Model year...Marking................Rod-pivot...Pivot-shock...Angle Shock-pivot...Wheel travel...Shock stroke
M900    2002...........372.1.003.2A........53mm      75mm            23.5°.............148 mm........ 65mm
ST4S...
S2R...
999 Bip.....................372.1.003.1A.........53mm      68mm            19°................128mm..........71mm
749/999R..................372.1.025.1A.........60mm      58mm           -21°................128mm..........56mm
Edit: Well, close to reasonable ...
EditII: Slightly better ....
EditIII: I've added wheel travel and shock stroke, will give a hint as to what fits where. I checked the linear 749R link in the Monster, but that would give very strange caracteristis, and shock stroke would have to be shortened.
Monster 900-2002 (sold, alive and well in the UK), 749R / 1100 HYM combo for track days, wifes / my Monster Dark 800-2003 (not entirely "Dark" anymore and a personal favourite) , 50% of 900SSie -2000 track bike for rainy days-now with tuned ST2 motor and Microtec ECU. Also parked due to having been T-boned on track.
