October 29, 2024, 07:56:14 PM *
Author Topic: quick question on valve adjustment.  (Read 804 times)
desmodoktor
« on: November 11, 2012, 07:20:09 PM »
i was just wondering if the belts have to  be loose when you do the valve adjustment ?
is it better to remove the cam shaft from the head and do the adjusment?
« Last Edit: November 11, 2012, 10:03:51 PM by svp88 » Logged
IG @desmodoktor & @ridingturtlegarage
« Reply #1 on: November 11, 2012, 08:28:28 PM »
Some people claim you can do the check and adjustment with the belts in place.  It is definitely easier with the belts removed.  Loose isn't enough.  Some models require removing the cam shafts.  No reason to on your old two valve.
desmodoktor
« Reply #2 on: November 11, 2012, 09:59:12 PM »
sounds good. thx howie!
DesmoTillDeath
« Reply #3 on: November 14, 2012, 10:15:45 AM »
Much easier with the belts removed. This way you can easily ensure you are at TDC for your given cylinder.
'01 900D: open airbox, K&N filter, termi slipon high mounts, Barnett lightweight clutch basket, 12VDC accessory port
'01 m900: Project; tail chop, raised seat pan, 999 tank, clipons, 900SS front upper half fairing, ST2 footpegs
'71 BSA B25T: Fully restored (custom). Clubman bars. POS
