full Staintune system on E-bay
Started by sofadriver, November 14, 2012, 05:09:22 AM
sofadriver
Mike in Tacoma
'08 S2r 1000 - Red on Red
'96 900 SS/SP
IBA 38181
Check out the star shaped collector compared to stock.
Is it a stock diameter pipe or 45mm, I wonder? Almost looks tapered on this phone screen.
I have seen a 45mm version for older Monsters in an old catalogue (years ago).
muskrat
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
dansamp
Does anyone know if this will fit an 02 M750ie ???
ChrisK
What do you guys know about Staintune? I have a Staintune system on my '98 900 and I don't really know anything about them.
I haven't had any, in-person experience with other Monsters so I don't really know how the Staintune compares to other systems. How are they compared to the other brands such as Termi, etc? I was considering shopping around for an exhaust update but now I'm wondering if I even need one.
1998 M900
2007 CBR600RR Track Bike
1980 Lambretta Moped
Supra Boats enthusiast
Are the  header pipes that polished or just the mufflers? Mufflers were quite common, but full systems relatively rare. I like the look of how they make the collector section. I was always curious about the performance of the Staintune full systems and what diameter tubing they used.
ChrisK
1998 M900
DesmoTillDeath
Would probably also fit 900 with open loop fuel injection. (no need for the O2 sensor ports)
SHINY........GROUND CLEARENCE......... [bow_down]
'01 900D: open airbox, K&N filter, termi slipon high mounts, Barnett lightweight clutch basket, 12VDC accessory port
'01 m900: Project; tail chop, raised seat pan, 999 tank, clipons, 900SS front upper half fairing, ST2 footpegs
'71 BSA B25T: Fully restored (custom). Clubman bars. POS
I suspect that would fit a 900 Monster.
AFAIK, 900 headers are not interchangeable with the small motor headers.
If you had same pipe sizes, I doubt you'd see a difference on the dyno between that crossover/collector and the OEM one.
Pretty though, for sure.
brad black
ss headers don't work on monsters.  different path through swingarm, different muffler location.
Brad The Bike Boy
http://www.bikeboy.org
True, SD and BB.
There are dyno charts around to show how effective the stock headers are and how very expensive aftermarket full systems may give 2 or 3 peak hp at the very top of the rev range. Not the best bang for buck for the average rider. The crude looking oem stamped collector is surprisingly effective.
I haven't seen a dyno comparison with the 45mm Staintune full system for the 900 Monster I once saw in an old catalogue. Maybe it may help a hot 944/964/984 with ported, big valve heads.
The beauty of the stock system is that it actually works quite well. You could take it to a pipe maker and have a 45mm version made or ask Staintune to pull out their old jig and make a special order (if it hasn't been recycled).
The biggest advantage of the Staintune full system is cornering clearance.  Oh, they look cool too.
The grade of stainless used looks way superior to the oem material. Polish the oem pipes and it doesn't last for long. The oem stainless looks quite "grainy". Those Staintunes look like they hold up real well.
A mate got so frustrated with attempting to polish his oem pipes he went and got them cad or nickel plated (can't remember which one).
