Best Brake/Clutch levers?
Started by Ryanc7, November 18, 2012, 08:02:22 AM
Ryanc7
Hi it is time to put away my baby for the winter so its time to start modding slowly and the first on the chopping block will be my levers.
I have small hands and I find the reach needed for the stock grips a little tiring for my hands so my question is.
What are the better levers to get a much closer adjustment?
And I am looking at ASV Levers and want to know what the big difference is between their C5 model 125$ or then F3 model at 90$
And if anyone prefers another brand I have very much open to suggestion
Thanks
I'm not sure any of the aftermarket levers are VERY much closer  :-\
Then again it doesn't take much to give you a better result.
Some CRG and ASV production series don't have the tab needed to push the brake light switch and/or clutch safety switch. Ask the vendor if 'yours' does.
With a shorter reach, please make sure (very sure) that the engagement point is professionally adjusted. I've seen many that are not adjusted at all - resulting in a lever that won't do it's job before it hits the bar. Even professional mechanics often don't understand the correct procedure. You can read about the procedure here (scroll down):  http://www.ducatisuite.com/leverchange.html
Barney
i'm very happy with my shorty crg rc2's.  i you search around the board, you'll find various opinions on the ebay knockoffs as well...
12 M1100EVO
09 KTM 200XC - sold. I cried.
70 Honda 450 Scrambler
Ryanc7
Quote from: shift1100 on November 18, 2012, 12:08:25 PM
They look pretty sick but are they 200 per lever? or for the pair? and how short can you get the adjustment on them?
They're about $200 for a pair.
Not sure about the adjustability, but the original CRG's can usually be adjusted overly short, IE barely adequate to disengage the clutch or get full brake before it's really close to the bar.
FWIW, I've got large hands and the original CRG's, and like the levers out quite far.
Hoping some of our small-hand members can chime in.
Ryanc7
As do I , any small handed people want to chime in?
S21FOLGORE
I have fairly small hands, but ...
I don't think you'd have to move brake / clutch lever THAT close to the grip. (unless your hands are really REALLY, extremely small.)
How small are your hands?
Are you holding the grip in the right way? (I'm going to post about this, with more detailed info, later. I'm in the middle of my laundry right now.)
Here's the example of "small hand VS Ducati monster S4R".
Brake
1)brake not applied
2this is where brake light switch clicks
3)brake fully applied
Clutch
1)clutch fully engaged
2)this is where you start to feel the clutch springs resistance
3)clutch lever fully pulled in
NOTE : I went through stock (brake) lever =>AVS lever (with stock master cylinder) => Brembo Radial master cylinder (comes with lever). If I were in your place, I'd skip "changing just levers" stage and get radial master for front brake.
As for the clutch, you know you don't have to pull in the lever that much when the bike is moving at certain speed ?
Unless you do a lot of riding in a congested city streets, you shouldn't have to move the lever THAT close to the gripl
Barney
#7
Quote from: Speeddog on November 18, 2012, 12:54:49 PM
this.
i like the short boys because i tend to use 1-2 fingers like the previous post's pics, and i dont like to have all that extra lever crushing my fingers.
if you like, i can snap some pics of them and post 'em up.
12 M1100EVO
Ryanc7
Yes please do post pics,, i was thinking short clutch long brake
uglyducky
my favorite levers ever are the FP racing tactical bi-folds for fit, finish, and adjustability but, alas, they don't make em for the radial masters that i'm aware of . . .
http://www.fpracingusa.com/
2001 996 Biposto - (sold)
bob795
I have CRG RC2 levers, the short ones and love it. They're adjustable and since I usually use two-finger on brake and 3 fingers on clutch, the short ones suits me really well. Replacing the levers was the first modification I did to my monster ... and it makes slow riding in heavy traffic (where feathering the clutch is a must) really comfortable.
2011 Husqvarna TE 630
2012 Monster 795
2002 Sportster 883/1200 (sold)
thought
I'd say the range of adjustment is pretty standard nowadays... I think the ASV's have a better range though with finer increments.
That being said... if you're just testing them out, I'd just get some ebay ones.  You can check reviews on this board, they're fine and they're sometimes cheaper than the shipping you'd pay for buying the name brand ones.
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
hunduc
fairly small hands here. i am using shorty pazzos for both and i love them. i was using four fingers on the stock ones, so i was a little hesitant going with the shorties, but they turned out to be great at the end. i am using two fingers now for pulling, and the pazzos can also be adjusted close enough.
Melfqw
I may be a bit late if you have already ordered levers, but just my 2 cents on ASV...
Hate them. They look amazing, and function perfectly. However, I like to ride without gloves, and I guess the oil on my hands must wear away the paint on the front of the lever that says "ASV". I've already had them replaced once, and the dealership said they called in and the guy from ASV told him that they had been having this problem a few times from a "bad batch" of paint. The replacement required me to send my levers in, and then for them to replace or refurbish them and then send them back. The replacement took a month or so and in that month I was forced back to my stock levers (ugh). Maybe 3 months later, and it is already happening again on the clutch side.
For a 200$ lever you would think that the levers would work for more than a month...
JoeB
I have Titax racing levers on mine. I put them on recently, and I love them. They are short levers, so designed for 2 finger clutch and brakes and the feel through the lever is fantastic.  product quality is great. I've used them on other bikes before so it was a no-brainer.
