February 24, 2025, 03:24:30 AM *
News: Please Help
Author Topic: 796/1100/848/Hyper Front Marchesini wheel on 696 ABS?  (Read 1979 times)
krafty
« on: November 25, 2012, 05:14:40 AM »
Hi all,
Does anyone know if it is possible to put a 796/1100/848/Hyper Front Marchesini wheel on 696 ABS bike? IF so what is required?  ie. spacers, rotors, etc. I know the bolt pattern for the rotors are different.
« Reply #1 on: November 25, 2012, 05:17:13 AM »
HM/1100 straight swap. 796 with rotors
848 you'll need 796 rotors
basically all 6 bolts are straight swap
796 5-bolts are same offset at 696
848 5-bolt are too offset, you need 796 rotors
krafty
« Reply #2 on: November 25, 2012, 05:24:57 AM »
Great, thanks! Is there anything special that needs to be done for the ABS? I haven't seen any 6 bolt front Marchesini wheel around, only the 5.
« Last Edit: November 25, 2012, 05:28:36 AM by krafty » Logged
« Reply #3 on: November 25, 2012, 05:29:00 AM »
you'll probably need the ABS sensor wheel, not 100% certain how it mounts.
My best suggestion is to take measurements, go to a Ducati shop and compare. take lots of detail pics.
« Reply #4 on: November 25, 2012, 05:29:46 AM »
the 6-bolt. you can look at the S2R/S4R
krafty
« Reply #5 on: November 25, 2012, 09:28:02 AM »
Ok, thanks again. I got my eye on an front 848 wheel and HM/796 rotors.
« Reply #6 on: November 25, 2012, 09:30:40 AM »
NI'm not 100% on the hm rotors. i do know the 796 are the correct offset and 5bolt
krafty
« Reply #7 on: November 25, 2012, 09:41:07 AM »
Ah, Ok. I thought the 796/HM were the same offset. I will keep digging before I make any purchases. At least I know the M796 rotors with 848 wheel will do the trick!
« Reply #8 on: November 25, 2012, 10:03:36 AM »
just a question... you're only changing the front?
krafty
« Reply #9 on: November 25, 2012, 10:43:21 AM »
No, I'm doing a SSS conversion. I already have the swing arm, rear brake line, rear hugger and the rear Marchesini, but been debating on doing the front wheel as well. I had problems finding info on the front wheel swap before and want to make sure I could do it w/o messing up the ABS or buying the wrong rotors.
Thanks!
« Last Edit: November 25, 2012, 10:46:31 AM by krafty » Logged
« Reply #10 on: November 25, 2012, 10:48:44 AM »
did you work out the speedo on the rear as well?
krafty
« Reply #11 on: November 25, 2012, 10:50:30 AM »
I was going to use the Healtech, unless you know of another method?
