February 05, 2025, 11:36:52 PM *
Author Topic: S2R Instrument Panel swap with new digital 696 panel  (Read 2110 times)
hawangatang
« on: December 12, 2012, 10:30:43 PM »
I was wondering if it's possible to swap a brand new digital panel from a 696 or whatever to my S2R. My tachometer is broken and my mechanic told me the thing is "non-serviceable"... I saw a tutorial on how to open it up so I may try and fix it.
But i thought it would be really cool
Thanks,
Hans
That which you manifest is before you.
www.hanshcwang.com
2005 Ducati S2R 800 (red)
« Reply #1 on: December 13, 2012, 04:02:59 PM »
Thanks,
Hans
Different ecu, different harness plugs, wiring changes...
No easy way as far as I know.
brad black
« Reply #2 on: December 14, 2012, 05:37:06 AM »
i'm sure the 696 dash gets a lot of its info via can bus.
Brad The Bike Boy
http://www.bikeboy.org
hawangatang
« Reply #3 on: December 15, 2012, 01:24:53 AM »
hmm thanks guys. I'm trying to think of what to do with my tachometer. It's not a terrible issue but it's definitely an eye sore... Perhaps it's a sensor issue?
Is there an engine speed sensor anywhere on the bike?  Huh?
Hans
www.hanshcwang.com
« Reply #4 on: December 15, 2012, 02:15:02 PM »
The signal for the tack comes from the ECU.  The ECU is getting proper info because the bike runs.  Check your connections at from the ECU to the tach, if you have the owner's manual there is a wiring diagram in the back.  If not, go here   http://www.ducati.com/services/maintenance/index.do  and download one for your bike.
hawangatang
« Reply #5 on: December 17, 2012, 03:22:50 AM »
awesome i will give that a try see if there are any loose wires.
hans
www.hanshcwang.com
hawangatang
« Reply #6 on: December 17, 2012, 06:02:47 PM »
okay i read the diagram and it says
BODY 9 (TACHOUT) and it's a Green wire. So. Where is Body 9 located?
Hans
www.hanshcwang.com
« Reply #7 on: December 18, 2012, 06:02:53 AM »
Of the 2 large connectors going into the ECU, one is body the other is engine.  BODY 9 is pin 9 on the body connector.
hawangatang
« Reply #8 on: December 18, 2012, 05:26:17 PM »
Thanks Duckstew, really appreciate your help. I'm going to try and see if it's just a loose connection. Otherwise I would have to buy a brand new instrument panel which costs 500 bucks.
www.hanshcwang.com
« Reply #9 on: December 19, 2012, 02:58:56 AM »
The wiring harness shouldn't be trusted entirely...  I've seen more than a couple in warranty parts bins.
hawangatang
« Reply #10 on: December 19, 2012, 03:43:12 AM »
Out of curiosity:
If i purchased the Nemesis ECU then I can basically install the 696 dash right? Of course, this would be like a 2 thousand dollar mod...
Hans
www.hanshcwang.com
