April 28, 2024, 07:20:24 PM
Team UnorthoDUX Ducati based land-speed racers New pic pg 19!
30
31
32
33
36
Topic: Team UnorthoDUX Ducati based land-speed racers New pic pg 19! (Read 205660 times)
Dirty Duc
I'd rather be an anti-
Re: Team UnorthoDUX Ducati based land-speed racers New pic pg 19!
Reply #450 on:
August 13, 2018, 07:44:17 PM »
So for the fast, gangbusters run yesterday, wheelspin in first and second.
It sounds to me like two cylinders, but just flat. When rich made a difference it was like 20% over a 5.3 stoich, and it feel even further on it's face.
Current plan for tomorrow is to base the map entirely on tps, set for 100% stoich with 100% tps, etc. Probably not great for real world driveability, but it takes fuel out of most of the map and I still have 25% available in Accel enrichment.
Ducatis on the Salt
Dirty Duc
Reply #451 on:
August 14, 2018, 10:39:18 AM »
Okay, speeddog had the right hint. The horizontal cylinder want firing due to salt bears. Moved the ground from the salt spray, and I have to cylinders again.
Ducatis on the Salt
Dirty Duc
Reply #452 on:
August 14, 2018, 05:53:47 PM »
So after moving the ground, we were back to intermittent good running... I blamed the coil, and cadged a couple of spares from the mayor of Wendover.
Once the offending coil was swapped out we discovered the hypothetical map did not work.
No worries, as I hadn't thrown away previous maps. While still far from perfect, certainly a decent starting point now that the bike runs.
Next run was back up in the 130 range, but still missing some top end to get it over there aero hump.
Started playing with timing a little, and then the day got called early for wind.
Ducatis on the Salt
Dirty Duc
Reply #453 on:
August 15, 2018, 03:46:51 PM »
This morning, I bumped the rev limiter to 12500, ran the extra timing from yesterday afternoon, and went 140 and 142 over the two measured miles of the short course. The morning line took forever, but then everything died down.
I bumped the timing again, and started to get funny running. It seemed to get better if I gave it some accelerator pump, so I bumped the fuel. Same thing. Dropped the timing back to the fast run, same thing.
This is a familiar operating mode that eventually ends up with a totally toast coil. So I swapped the other one out with the second of the recent acquisition.
Wind came up, and we called it a day before it was official.
Ducatis on the Salt
Reply #454 on:
August 15, 2018, 04:22:24 PM »
Why is it burning up coils?
Dirty Duc
Reply #455 on:
August 15, 2018, 04:54:39 PM »
I'm not sure. Current theory points to dwell (3.0 ms doesn't seem out of line for internet lore on Corvette MSD coils) or rpm.
I am currently leaning toward rpm being the problem right now. The plan is to pick up a couple of pairs of panigale coils or something along those lines that can deal with rpm.
Ducatis on the Salt
Reply #456 on:
August 15, 2018, 07:24:22 PM »
OEM 'Stick' coils are no good?
Dirty Duc
Reply #457 on:
August 15, 2018, 07:43:32 PM »
We've been chasing so many issues, I'd forgotten that was an option.
Are they available for a less than unreasonable price?
Ducatis on the Salt
Reply #458 on:
August 15, 2018, 08:15:34 PM »
Quote from: Dirty Duc on August 15, 2018, 07:43:32 PM
~ $210 ea brand new, same unit for 749, 999, S4Rs, S4Rt
Dirty Duc
Reply #459 on:
August 15, 2018, 08:35:33 PM »
Do they publish dwell specs or do I have to guess?
Ducatis on the Salt
Reply #460 on:
August 16, 2018, 06:17:32 AM »
Quote from: Dirty Duc on August 15, 2018, 08:35:33 PM
I've not seen any dwell specs, but I haven't been looking either.
Dirty Duc
Reply #461 on:
August 26, 2018, 10:32:53 PM »
I bought a used set of 848 coils, cuz they were the cheapest, and a cheapo digital o-scope from Amazon. notionally, that should be enough to crack the code.
Ducatis on the Salt
Dirty Duc
Reply #462 on:
May 19, 2019, 03:35:48 PM »
And the new season begins.
https://photos.app.goo.gl/k2yussPqFhHkmgEi8
New fuel tank, new seat, new front end, new water tank, airbox back on...
Ducatis on the Salt
Reply #463 on:
May 20, 2019, 12:20:06 AM »
Looking forward to seeing how the mods go👍
Dirty Duc
Reply #464 on:
May 20, 2019, 08:22:33 PM »
Quote from: Speeddog on August 16, 2018, 06:17:32 AM
How about wiring? I have three wires, red, yellow, and black, but only one connector...
I would assume red is hot, yellow is command, black is ground?
Ducatis on the Salt
30
31
32
33
36
