where to get intake runner "valve/nipple thingy"
Started by memper, December 20, 2012, 12:23:58 PM
memper
I lost one of them when I removed the emissions stuff and I need to sync my carbs.
Quote from: memper on December 20, 2012, 12:23:58 PM
What thread size do you need?
memper
#2
Def an M5. Threads are 1mm or .5mm
'99 750
memper
Or, direct from the source:
http://www.motionpro.com/motorcycle/partno/08-0218/
or even better, with a 500mm hose and capped end for easy access:
http://www.motionpro.com/motorcycle/partno/08-0216/
I've got some extras if you want to go that route.
garryc
We aussie heathens can't buy direct from motion pro so need alternate sources for their stuff
jerryz
buy them from carbtune uk they have 2 sizes
and brass or plastic but brass is best for permanent fitting
Quote from: garryc on December 22, 2012, 06:57:00 PM
Fair enough, didn't know you were an Aussie Heathen. [laugh]
memper
Howley
I think my bike has two different size threads on the intake manifolds. Could that be true? I wanted to sync my carbs ages ago but I only had one fitting that fit.
memper
Yes, I believe. The fittings on the inside of the runners are bigger than the ones on the outside. I'm just gonna order a couple new ones.
