February 24, 2025, 12:46:44 AM
Bar end weights for a bar end mirror.
Topic: Bar end weights for a bar end mirror. (Read 1428 times)
freeclimbmtb
From Zero Member to
January 02, 2013, 07:54:28 AM »
Alright so I have the CRG Arrow bar end mirrors, which I love. Only problem is the pinch bolt that holds it on the bar end adaptor is wearing holes in my right hand glove from being on/off the throttle. Anyone have a suggestion for a different (possibly weighted) bar end that will let me keep these mirrors? Maybe just move the mirror clamp out 1/2" or so so my glove doesnt rub on it?
2011 Monster 796 ABS
kemorobbie
Re: Bar end weights for a bar end mirror.
January 02, 2013, 04:12:02 PM »
Check out the Motovations bar ends. They are weighted and will push your mirrors out just enough I bet. That's what I am running without problems.
freeclimbmtb
From Zero Member to
January 03, 2013, 03:59:08 AM »
Just took a look...those look like they will put the mirrors exactly where I have them, they just have a slider out on the end.
Motovation:
CRG:
Looks to position the clamp in the same spot...the search is on!
Jimmy6tring
January 03, 2013, 10:45:32 AM »
I have an S4 which has solid bars which meant the CRG adapters wouldn't fit. I found the RhinoMoto adapters/sliders an easy solution and I'm happy with them. They're not weighted but they might give you a little more room on the end of your bar:
IMG_0375
by
jimmy6string
, on Flickr
http://www.e-securedsite.com/rhinomoto/store/myProducts.cfm?parentcategoryid=4%7CBarend%20Sliders%20and%20Mirrors&productID=126&showDetail=1&categoryID=91
|Ducati%20Barend%20Sliders&vendoridtodisplay=0&filterFor=&collection=4%7CBarend%20Sliders%20and%20Mirrors
freeclimbmtb
From Zero Member to
January 03, 2013, 11:53:42 AM »
Now were talking.. thatll take some looking into.
JEFF_H
January 03, 2013, 02:52:36 PM »
the rhinos are steel-bodied so they are a little heavier than the various alum ones.
you will need the flat shaped slider to fit with the CRG Arrows
freeclimbmtb
From Zero Member to
January 04, 2013, 03:50:27 AM »
Quote from: JEFF_H on January 03, 2013, 02:52:36 PM
Good call.
