February 24, 2025, 12:39:31 AM
Aftermarket dash on2002 - 2008 Monster: How to run indicators?
Topic: Aftermarket dash on2002 - 2008 Monster: How to run indicators? (Read 1750 times)
brad black
January 10, 2013, 02:09:31 PM »
has anyone fitted an aftermarket dash to a 2002 - 2008 monster with the indicator control in the dash board? and, if so, how did you run the indicators?
Brad The Bike Boy
http://www.bikeboy.org
Jarvicious
The guy in my avatar wants your
Balls
Re: Aftermarket dash on2002 - 2008 Monster: How to run indicators?
January 10, 2013, 02:42:58 PM »
What kind of wiring harness are you using to adapt to the aftermarket dash? I'm assuming you're going for a non cut-and-splice approach?
We're liberated by the hearts that imprison us. We're taken hostage by the ones that we break.
accrocker
January 10, 2013, 09:24:08 PM »
I fitted an acewell gauge to my '07 695. I run the blinkers with a solid state, load dependant relay similar to the motogadget m flash unit. I use that to send constant battery voltage to the neutral pole on the blinker switch and then wire the blinkers themselves directly to ground. When the blinker switch is engaged, the load from the blinker causes the relay to engage.
07 monster 695, tail chop, custom flashed dp ecu (no more immobilizer!!) high mount marving megaphones, pod filters and an Acewell 4000 gauge set
brad black
January 11, 2013, 03:40:10 AM »
Quote from: Jarvicious on January 10, 2013, 02:42:58 PM
this is a pre emptive question due to a customer with a dead dash and thoughts of replacing it with non genuine.
Brad The Bike Boy
brad black
January 11, 2013, 03:48:22 AM »
accrocker: bang on. i googled the motgagdet and it looks easy enough.
so the relay supplies the voltage to the switch and also gives the on/off flash rate. you connect switch out l/r to indicator power wires l/r and earth the other indicator wire.
i'm being the voice of reality before he brings in some aftermarket dash and asks me to fit it and 5 or more hours later i give him a bill and he falls over sort of thing.
Brad The Bike Boy
accrocker
January 11, 2013, 09:24:48 PM »
It isn't so bad. It took me maybe an hour to complete the wiring changes, and the wire diagram I was working with was fairly rudimentary. Getting rid of the factory gauges was the best change I made to the bike. Knowing that my gauge and associated immobilizer won't leave me for dead every time it rains is worth it's weight in gold.
January 11, 2013, 10:17:46 PM »
which relays did you use?
brad black
January 13, 2013, 04:10:05 PM »
accrocker: which acewell did you use? i'm fitting a ACE-3963. do you have any photos to share?
Brad The Bike Boy
accrocker
January 20, 2013, 03:58:03 PM »
I'm using one of the 4000 series gauges. Analog tach with digital speed and other vital stats. I had a thread about it several years ago on here. If you search ace well it should pop up with a few of my photos. The gauge was a pre production model I got from a friend of mine who was a development engineer at electrosport so it might be a bit different than what they are presently offering.
