removing starter 620ie 2002 how?¿
Started by cmejia1978, January 10, 2013, 06:48:57 PM
cmejia1978
hi! well I am trying to clean all the spots where I see oil on my case, I already took the 1 nut on the left side, I see the manual and there are 2 more to go in order to take the whole starter away from my cleaning space... but how do I get to the other 2  [bang] ? Do I have to take the left cover off and then there is my secret treasure?¿ I have a 620ie 2002 thank you!
cmejia1978
Gonna remove the left cover in 3..2..1...  [popcorn]
cmejia1978
you have to remove the left side cover, its a pretty easy task.  Just search for some sealant.
you have to rent a steering wheel puller and use some long bolts. I usually mine them from the clutch cover, but seeing how it is a wet clutch, not much help i can give you. Maybe the belt covers have a few long bolts u can get. You'll need some washers too.
